46-480 Rear Cabinet Cover
Hello everyone.  I've recently acquired a Phlico 46-480 and am in the process of restoring both the electronics and the cabinet.  The cabinet is in pretty good shape but when I got the set it was missing any type of rear cover.  I've looked pretty closely at the cabinet's rear and haven't seen any screw holes or other mounting hardware which would secure a back cover.  This begs the question:  Did this radio originally come with any kind of a back cover?  If not I'm OK with leaving it open but if it did have a cover I'd like to fabricate a new one.  Any pics or information on this would be greatly appreciated.
       Pete
I have seen some 1946/47 Philco consoles with a cardboard cover over the speaker compartment only. But the radio portion had no back.
Keep in mind most prewar radios, and some postwar models as well, never had backs. It was understood that parents would teach Junior and Sally to stay the heck away from the back of the radio. Common sense, you know. That thing that has all but disappeared today. Icon_rolleyes
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1048 online users. [Complete List]
» 2 Member(s) | 1046 Guest(s)
