Source for Grille Cloth for 38-116XX
Hi Guys    Just trying to stay ahead of my restoration of my 38-116.  Where, if any, is a good place to buy some Philco Chevron Grill Cloth.  Mine is in need of replacing because of the wear and tears of life.
  Thanks for any responses and have a great day.
  Dick
It looks like Kenny Richmond no longer sells that pattern (it was for 1935-1937 Philcos, btw).
And Radio Daze no longer carries the 1938 Philco pattern. (It was not truly authentic anyway, but was somewhat close.)
So, madsowry, it doesn't look good for you as far as finding appropriate 1938 chevron cloth.
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1092 online users. [Complete List]
» 2 Member(s) | 1090 Guest(s)
