question about a Philco Tropical Model
Threads: 1
City: ATHENS
State, Province, Country: GREECE
Threads: 269
City: Bandon
State, Province, Country: OR
Threads: 269
City: Bandon
It would appear based on the fact that the turn table was made in England (assuming the turn table is original to the set) that the entire set was probably made there rather than in the US. Unfortunately we don't have much information on Philco Tropics made in England. Hopefully someone on the Phorum will be able to provide you with some additional information. If you had a photo of the back of the radio chassis, there is often a label or plate with model number information on it.
Threads: 23
City: Wellborn Florida
Voltage and Hertz would be right for Greece if it is a English made set. 1948-1950 time frame is when England starting using the wall outlet and plug they use today please post a picture of the plug on the power cord which should be 2 round pins for Greece. Welcome to the Phorum
If the unit still has its original back, it should have a model number printed on it. It will likely be four numbers, preceded by an A or a B - for example, A.1234 or B.2345.
If you can share this information with us, we might be able to track down something if it is available.
Unfortunately, service (and other) information for British-made Philco Tropic receivers is not always available anywhere, not even on the UK Vintage Radio Repair and Restoration forum.
Threads: 1
City: ATHENS
Thanks you so much for your welcome Ron and David! yes the unit still has its original back, and the model number printed on it is A. 3661. Its definitely made in Britain.
The plug on the power cord is not the original. The present has 2 round pins as the model has been in Athens, Greece since the early 50's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Threads: 1
City: ATHENS
Thank you for your welcome to the Phorum Ron and David.
The unit still has its original back and the model number printed on it is A.3661. The original plug on the power cord does not exist anymore. The present has 2 round pins as the the unit was in use in Athens, Greece since the 1950's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Thank you for furnishing the model number.
The UK Vintage Radio Repair and Restoration group issued a DVD filled with schematic diagrams and service information for many British-made radios. I have a copy of this DVD and I looked. Unfortunately, your model is not listed in this DVD set.
I am sorry I cannot help you further on this subject.
Threads: 95
City: Omak
State, Province, Country: WA
Hello Evangelos,
Welcome how exciting is this it is nice to see someone here from Greece !
Threads: 1
City: ATHENS
Thank you Ron, for your generous help! Hello Richard, greetings from Athens!
All the best,
Evangelos
Correct model 84 Ac plug an cord type
From what I read Philco went to using brown rubber power cords in 1936, so cloth was used in the 1935 and earlier models...Arran — 11:25 PM |
Hi Bruce,
I have not worked on an 84, but in general, power cords for almost any radio prior to 1938 was cloth covered...MrFixr55 — 08:34 PM |
Restoring Philco 38-14
OK, well, so after staring at the sch again, I realized the problem had to be the #12/12A padder.
I put a scope on the o...morzh — 08:15 PM |
Hello Bruce,
I mostly use brown far as my cloth powercords go !
Here is the plug that I have used bakelite Acorn style...radiorich — 08:05 PM |
Looking for as correct as can find the right Ac plug an the correct colored cloth line. Ive seen many old photos but mos...Bruce — 04:13 PM |
Rod
Two Y-caps make sense if you use them from L/N to the chassis; this is only makes sense in the transformer radios...morzh — 10:11 AM |
Mike, I'm curious about a specific use of he Y cap. Lately I've seen a single cap across the power transformer primary. ...RodB — 09:01 AM |
hello morzh ,
That sounds like a plan !
Sincerely Richardradiorich — 07:45 AM |
Richard,
It helped some, but I still had the whining when engaging the rear power strip (I did not realize it was fro...morzh — 07:07 AM |
Hello morzh,
Yes , that dreaded hum in my room where i do alighment I have my cable modem and router plus desktop plus ...radiorich — 11:25 PM |
There are currently 3059 online users. [Complete List] » 2 Member(s) | 3057 Guest(s)
