Philco Model 60F Sad story
Bought a Philco Model 60F Console some time ago.  Dusted off the cobwebs and began looking around.  The type 78 tube was broken inside the shield so I ordered one.  The line cord had nearly dissolved, cut it off and proceeded to see what the old girl needed.  Someone had been poking around, two of the "filter" caps ( the ones in the big rectangular can) had been replaced with Sprague units, looks like in the 50's or 60's.  I disassembled the two 8UF electrolytic caps, put new parts inside and put them back.
The speaker field coil was open, so I disassembled it and found some arcky-sparky spots between the bobbin and the hum-buck coil.  I got to picking around in the carbon spots and found the burned off wires.  I ohmed the one going to the inner part of the coil and one of the field coil connecting wires and got 1100 ohms! Yipee!!.  I was able to reconnect the two ends, secured the fragile splice with super-glue gel and lots of fingernail polish.  Put the speaker back together, and I'm sure it'll work again.
The Grommets for the tuning cap have shrunk and turned into concrete, and the dial face is broken at one end and all the numbers have rubbed off.  Ordered new Grommets from renovatedradios.com.  Ordered an new dial face from Radiolaguy.com.
Philco QC must have been pretty crappy back then, as several connections are not even soldered.. The wires are crimped around the lugs, but nobody added any solder.  Friday afternoon maybe...ha...  Its a wonder the radio ever worked.
Getty antsy and want to apply some power (thru a variac, slowly of course) so I measured the power transformer coils.....aw crap.  The primary is open!!  Sure wish I had checked this first.  well I've got so much into this radio already, I have to continue.   The schematic doesn't list voltages, So I don't know what the HV secondary is.  I looks like Philco used similar circuits (at least the power supply) for many different models.  Anybody know what the HV is for this model 60F?
Thanks Folks....
Marty K.
680v, 6.3v, and 5v.
Thanks Terry, I have something to go on now. I can look for a replacement or kludge something in to see if this radio is worth it once i power it up. I ought to build a HV bench supply like I had many years ago.
Marty K.
There is a gentleman over on ARF that is selling a Philco 60 chassis for $8. Look in the classifieds.
did you check to see if the power switch is ok?
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2355 online users. [Complete List]
» 2 Member(s) | 2353 Guest(s)
