model 50-1718 not working
can anyone tell me this. my model 50-1718 was working and now it doesn't none of the tubes light up when its plugged in. if one of the tubes are bad will it keep my 50-1718 from working. if it is a tube how do i tell which one is bad.
thank you all i am new to this but love old philco radio probably going to buy 3 more this weekend not model 50-1718 but other ones.
Hi Jim,
Yes on your set if one of the tubes filament is burned out (open) none of the others will lite up.So I've got a few questions for you. Can you read schematic? Do you know how to count the pins on your tubes? Do you have a volt/ohm meter? Schematic is here http://www.nostalgiaair.org/PagesByModel...013683.pdf
Terry,
answers to your questions 1st yes i can read schematics, 2nd yes i think i know how to count the pins, and yes i have a voltmeter.
Ok, So to test the filament on the loctal tubes measure across pins 1 and 8 and the octals across pins 2 and 7. Should show a very low resistance if good.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 746 online users. [Complete List]
» 1 Member(s) | 745 Guest(s)
