model 50-1718 not working
can anyone tell me this. my model 50-1718 was working and now it doesn't none of the tubes light up when its plugged in. if one of the tubes are bad will it keep my 50-1718 from working. if it is a tube how do i tell which one is bad.
thank you all i am new to this but love old philco radio probably going to buy 3 more this weekend not model 50-1718 but other ones.
Hi Jim,
Yes on your set if one of the tubes filament is burned out (open) none of the others will lite up.So I've got a few questions for you. Can you read schematic? Do you know how to count the pins on your tubes? Do you have a volt/ohm meter? Schematic is here http://www.nostalgiaair.org/PagesByModel...013683.pdf
Terry,
answers to your questions 1st yes i can read schematics, 2nd yes i think i know how to count the pins, and yes i have a voltmeter.
Ok, So to test the filament on the loctal tubes measure across pins 1 and 8 and the octals across pins 2 and 7. Should show a very low resistance if good.
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
There are currently 650 online users. [Complete List]
» 2 Member(s) | 648 Guest(s)
