American Bosch model 515.
Icon_problem Audio output transformer has open primary. output tube is a 42 and schematic about 3 watts+/- of power. any suggestions as to what I need to replace the transformer Icon_confused:
Pretty much any output transformer used with a another 42, a 6F6, 6V6,or even a 6BQ5 will work as a replacement, there are others of course but the plate impedance is pretty close between those tubes.
Icon_wave thank you for advise--will do.
Or if you want to live life on the edge you can use a 6.3v filament transformer. the 110v side goes to the plate circuit and the 6v side to the speaker.
Agree with all, you'll get some audio if everything else is OK. Then you can fine tune it and get a proper transformer
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
