Philco 16B code 121 Tombstone ...Questons
I bought this 16B at auction on Friday . It is a tombstone , 2nd variation Cabinet with a code 121 16B chassis.... see pics
[Image: http://home.ptd.net/~landd/16Bauction.jpg][Image: http://home.ptd.net/~landd/16Bauction2.jpg]
I've already orderd the on/off/ vol switch from Mark Oppat.
The friction dial drive repair I've got covered, as the large can restuff.
Questions :
1) It hase the early still hex knobs ... it's missing one . Is it supposed to be the larger hex stlye or the same size as the others ?
2) it's missing all the metal inserts for the knobs.... where to find ?
3) if the shadow meter needs to be rebult does anyone do these ?
4) any alterations/ updates to the elec. suggested ?
5) paper work I should order ?
Thanks ... David
Hi David, and welcome!
Also, congratulations on your find.
The cabinet like yours, with the more pronounced "peak" to the top, usually holds a Code 125, 4-band 16 chassis. Having seen a photo of your set elsewhere, and seeing the hole for the tuning knob shaft and that it is a small hole, this proves your set is 100% original. Obviously, when Philco switched from the flatter top to the more pointed top of this style cabinet, they still had a few leftover 16-121 chassis, so they drilled a small hole for a single tuning shaft in the cabinet. Models that use the 4-band chassis have a large hole so the concentric tuning knobs will fit.
Anyway, to answer your questions...
1. The tuning knob should be a large hex knob, with a set screw so that the two-speed tuning of the 16-121 chassis can be accomplished easily. The band switch knob should also be a large hex knob. The volume and tone knobs are small hex knobs.
2. I do not know the answer to this one, sorry.
3. Not that I am aware of at present.
4 & 5. I suggest you purchase the Philco 16 Code 121 schematic package from Chuck, so that you have all of the factory production changes as well as a nice, large 11" x 17" schematic and all available factory data.
http://www.philcorepairbench.com/schematics.htm
Thanks Ron... Icon_angel
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Need Help to ID this radio 11 tube Philco
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
There are currently 850 online users. [Complete List]
» 2 Member(s) | 848 Guest(s)
