Philco Socket Power Type B-60
Hi all, Recently came across this interesting piece of history. Would like to do a cosmetic restoration before attempting to get it working. Has anyone restored one of these, in particular, the right color brown for the case. Cosmetically there is little rust on the outside of the metal cabinet. Most of the paint is gone. A few spots still have the original paint. It is hard to tell if the paint was smooth or a wrinkle finish. The bottom inside of the case is quite rusty-maybe from spillage of the borax and water solution from the 4 jars? Thinking of trying muriatic acid and a wire brush to clean the inside. The brown bakelite panel insert is in very good shape. Should clean up nicely. Any thoughts? Thanks, Ken Kidd
...and, if you need the service info for Socket-Power unit, I have it through my site.
That's is good condition, compared to most I've seen.
Chuck
Thanks Chuck, Will take you up on your offer. I'm assuming the 2 tar filled cans have the caps and maybe a resistor or 2 in them. Initial cold check of transformer indicates it is good. Will post in electronic section when the time comes if I have specific questions on the electronic repair. Ken
Don't use muriatic acid, it will take the rust off but it will also make it rust again. What I would do is try electrolysis to strip the old rust and paint off, basically you need a battery charger or DC power supply, a piece of scrap metal, baking or washing soda, and a bucket of water, there are several good how to videos on your tube. Another method if you want to try preserving some of the original paint is soaking the cabinet in a 6:1 mix of molasses and water for about a week or two. It looks to me like the original paint was some sort of crackle finish, I don't even know if you can buy it anymore but there used to be a few recipes on how to make it.
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
Sorry Murf, technical is what I do. OK, Unlike the Western Auto Tru-Tones, this True Tone is a Wells Gardner set. Th...MrFixr55 — 09:31 PM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
Testin a speaker and output transformer Trutone A2-G
Hey Murf, this shouldn't be too difficult if it happens all the time. I'm assuming this is the 1938 Wells Gardner A2 wit...RodB — 05:46 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
