Latest project - a Philco 39-6
I picked this little radio up at an antique mall in Cincinnati last weekend. It is the undocumented variant of the 39-6, with different grille cutouts like this one in the Gallery:
http://www.philcoradio.com/gallery/1939a.htm#b
The cabinet looked very nice overall, but had a spot on top where the finish was missing, as if something had been placed on top like a drinking glass.
I decided to try a spot repair to the top of the cabinet. So far, it's turning out pretty good. Not perfect, but certainly acceptable. I'll be making a trip to Evansville this week to pick up some semi-gloss spray lacquer to finish the job. That's the bad thing about living in a rural area...for the most part, you can't find lacquer around here. This is amazing to me, since Jasper (12 miles away) is well known as a town of furniture manufacturing.
The chassis was another story. Ugh! The thing was advertised as "working," and indeed it did work. However...the original power transformer (as with all 1939 USA Philcos which used power transformers) had rubber-covered wiring, and the rubber was dried out. If the wires had been slightly disturbed, the insulation would have started flaking off and the transformer could have easily shorted out. Icon_eek
The chassis itself was a mess of yellow cadmium powder and severe rust spots on top. All of this was carefully cleaned off, and the chassis was then primed, and later painted. I am currently finishing up work to the chassis - none of the capacitors had been replaced except for one electrolytic, which was replaced decades ago. Yes, one of the original wet electrolytics was still functioning!
I have replaced all of the paper caps. I have carefully removed the crumbling rubber from the power transformer leads, and replaced the insulation with color-coded heat shrink tubing to match the original colors. I still have to rebuild the electrolytic cans, reassemble the power transformer (the bells are out in the garage, having also been primed and painted, and I'm waiting for them to dry) and install these parts.
I did not take any photos during the restoration process, but now I'm thinking I probably should have. However, I will post a couple photos when it's all done.
The chassis is finished!
[Image: http://www.philcoradio.com/images/phorum/ARF/016-1.jpg]
[Image: http://www.philcoradio.com/images/phorum/ARF/020.jpg]
[Image: http://www.philcoradio.com/images/phorum/ARF/025.jpg]
I won't get to the cabinet until later this week; I'll post a photo once I have applied the final coats of lacquer to it.
I'm sure it didn't look this good the day it left the factory. Very well done indeed.
Hats off to you sir! Nice job indeed!! Does it work? ( just kidding)
Mr.Ramirez...Very nice work! Where do you get your capacitors?
Jimmy
I buy my capacitors from a fellow in your area...Bob's Antique Radios (Bob Piekarz).
http://www.radioantiques.com/supplies.html
I forgot to mention that, unlike most USA-made 1939 Philco sets, this 39-6 had cloth covered wiring under the chassis instead of the usual rubber insulated wires. (The power transformer did have rubber-covered leads, as I mentioned in a previous post.) I only replaced a few of the cloth-covered wires; chiefly those visible above the chassis. However, the majority of the wiring remains original.
Mr.Ramirez...I met Bob at a swap meet back in April and saw him last Sunday selling at another swap meet. I saw your caps and they sure looked familiar....small world. Icon_biggrin
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
There are currently 1116 online users. [Complete List]
» 1 Member(s) | 1115 Guest(s)
