Zenith 6S52 cadohm
Hello fella's
Have a 6S52 chassis I am playing with and have a question or two about the cadohm resistor.
Mine checks,
270 ohm
112 ohm
1.4 K
5 K
and 10.1 K (this one was replaced with a 10K, but did not disconnect one leg.)
Riders specifies 250/74/83/920/4940 and 11M.
I am assuming that all but the 270 and 112 are the only values that are not specified in K ohms.
Can someone specify the correct values in todays standards to order to replace these?
I guess that  I will probably need about 5 watt resistors to build a new cadohm resistor.
Suggestions?
Have only repaired one of these before, so I am learning.
murf
Murf,
You're wise just to replace the whole candohm on a terminal strip. I usually use 5 or 10 watt ceramic resistors. Your new values should be close to
250 ohms / 74 ohms / 83 ohms / 920 ohms / 4,940 ohms / 11,000 ohms. The point between the 83 and 920 should be to chassis ground.
Thanks for the reply.
I agree and will replace the cadohm as it has been repaired once already.
murf
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
By the way. osanders0311 Take a look here: Dial cord stringing Guides May be here you can fount correct string settin...Vlad95 — 11:15 PM
There are currently 1097 online users. [Complete List]
» 1 Member(s) | 1096 Guest(s)
