11-05-2023, 12:06 PM
works fine on isolation transformer. on ac line smokes vol control and 325 w/w resister smokes. suspect pwr xfmr
37-84 code 122
11-05-2023, 01:09 PM
Hmmm rather odd. The volume control doesn't really have much to do with any thing in the p/s. The sw does though. What happens if you run it w/the 5Y4 unplugged? Are the plate voltages even between the ct and the plates at the 5Y4 socket? Do you have the chassis connected to an earth ground? Have you done any service work to the chassis? What does #30 measure in ohms?
https://philcoradio.com/library/download...%20244.pdf When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
11-05-2023, 04:10 PM
How about that 0.005uF cap from line to chassis? Does it smoke if you rotate the power plug while operating without the IT?
« Next Oldest | Next Newest »
Users browsing this thread: 2 Guest(s) |
