Zenith model identification 1937
Hullo everyone,
A Zenith 6 valve set from 1937 has come across my workbench and I am hoping someone may be able to help me identify it.I think it is 1937 because it has a rubber date stamp on the  cardboard speaker  surround of that date. The octal valves are pretty standard for the time - 6A8, 6K7 , 6H6 ,6J5 or 6C5 (no identifying mark on valve)and 6F6 output tube. The rectifier is a little unusual , though , being a 5Y4.
Some time ago faced with a similar problem a Phorum member was kind enough to send me a link which outlined all the radios that used a particular valve lineup.I'm hoping that they might send me that link again.
It has a 6 inch e.m. speaker with both field and output transformer primary intact. On the back is an aluminium tag listing the serial number as R555222.Inside the chassis at the back is a green printed cardboard label bearing the code R250. If anyone can throw any light on what model Zenith this is I would be most grateful. Cheers, everyone
Gday Mate!  I tried on this site to find your serial number but it is not listed.  Anything close comes up as 1938.  Here's the site for you to try.  https://grillecloth.com/zenith/zenith.php
Good Luck and welcome to the Phorum.
Dick
Thank you Madsowry for your help. I have been able to identify the set and download the schematic from Radiomuseum. Your help is much appreciated.
And the model is…?
Joe
Hi Joe, Thanks for your enquiry and my apologies for late reply - I have been on holiday and away from my computer. It seems that I have a Zenith Model 6 S 203, 6 S 222 ,6 S 223, 6 S 229 ,6 S 239, 6 S 241 (5638 Chassis). The schematic covers all of them . It was delivered to me sans cabinet so I don't know what the cabinet style is. I haven't gone in yet but , as our local vintage radio group is having a Zenith themed meeting this Thursday I might put aside another set I have on the bench and see what is going on in this set and perhaps take it to the meeting.If I can get it going ! Cheers.
Thanks!  Keep us informed as to status.  Joe
Joe
Hi everyone - good news! This Zenith set now goes , and goes really well.I have replaced all the wax paper capacitors , some of which were original Zenith ones and the rest ones that had been replaced earlier.Several resistors had gone high as well.Once the bias on the 6F6 was put right the tone improved pleasingly too. At this stage it seems sensitive and not in need of any urgent realigning - so smiles all round and something to take to our Zenith themed meeting this Thursday.Thanks for your interest everyone , and an especial shout out to Madsowry for pointing me to the model and schematic , and for his genuine Kiwi greeting !
Philco 16B Parts
The 16B's in the tombstone cabinet sport a 10 1/2" spkr vs the older cathedral sets which uses an 8". The p/p ...Radioroslyn — 12:58 AM
Philco 38-7 Oscillation
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 11:16 PM
Philco 38-7 Speaker
I know that when I first started working on this radio, I did not even have a speaker. Once I finally found one it was n...tludka — 11:00 PM
Philco 60 Squealing
I seem to remember eliminating a squeal by changing the IF frequency by a few KHz. Not that you should put too much tru...fenbach — 08:48 PM
Philco 42-390, code 121 speaker
These speakers pop up on eBay regularly, even if at bloated prices. Honestly, have not seen many parts on swapmeets.morzh — 08:38 PM
Philco 38-7 Speaker
The put-put is not like the speaker problem.morzh — 08:29 PM
Mission Bell Model 19A Car Radio
Hello everyone,  As mentioned in my last post I was going to see if the vibrator / rectifier section could be persuaded...Antipodal — 08:21 PM
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
