Majestic model 939 dial string diagram
Hello guys,
Have a Majestic model 939 console that needs the dial string restrung.
Anyone here ever done one of these?
Don't even see where you can remove the front panel to get at the pulleys.
Have removed the glass which exposes a piece of felt.
If that were removed, there is an opening in the front panel.
Looks like a real bear to get in there to install a new string!
Have not found a dial cord diagram yet.
Suggestions?
murf
Figured it out today. What a basturd to install once I figured out the puzzle.
Anyway, its now done and working great!
Thanks, murf
Restringing....everyone's "favorite" Icon_smile
I actually don't mind restringing dial cords, though I'm probably a bit rusty with it now. I have a thing with repairing 8 track cartridges too, but some people like knitting. The pulleys may be on the back of the back plate, on some sets the plate comes off and they are mounted on some brackets, on others they are riveted onto the plate itself, I'm not speaking of this model just generically. Without seeing it I really have no idea how the string would have been routed, but there is usually a drum on the tuning cap with an expansion spring on one end, and just the cord on the other, but there is a lot of variation, this isn't permeable tuned is it?
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
There are currently 7815 online users. [Complete List]
» 2 Member(s) | 7813 Guest(s)
