replacement dial light idea!
Hello Everyone,
I am finishing up on my Arvin model 664A that was restored years ago by me.
One of the things that I want to do is to find what would be a good substitute for the dial lamp which is night light type bulb .
It is just too bright and produces to much heat . I worry about the Dial cover warping again .
Good news I found this LED bulb from Amazon
I wanted to post this to let you guys know that this bulb works well and does not interfere with the AM radio band .
Figure this LED is using a capacitor dropper instead of electronics circuit .
H
One thing I want to do is to find what would be a good substitute for the night light dial bulb. It is just too bright and produces too much heat. I worry about the dial cover warping again
That's about what I would use. Half a watt instead of seven. Little worried about the "Warraney" though.
E12 7watt replacement nightlight LED bulbs are available for under ten bucks at most Big Box and Hardware stores. I'd recommend 2000k-2500k bulbs for closer yellow color. Take care and BE HEALTHY! Gary
I just checked Amazon and they are 5 or 6 for $8, depending on whether you want clear or frosted glass. If you look hard enough you could probably find colors. Nice bright green glow might be attractive.
Hello Guys,
Well thank you for your input and I did buy a LED bulb to try see how it looks and Rod I too thought about using a colored bulb instead the clear one that was in the set .
I have a GE radio with a C7 in it. A friend suggested I use colored bulbs do Christmas.....Paul.
[Image: https://www.radiomuseum.org/images/radio...980331.jpg]
Hello Paul,
Yes,that is one idea !
Have tried LEDs found them to be hit or miss loud hum in the set. Like using XMAS bulbs also the dollar store sells a  pack of clear bulbs at 4 watts so less heat.
Philco 16B Parts
The 16B's in the tombstone cabinet sport a 10 1/2" spkr vs the older cathedral sets which uses an 8". The p/p ...Radioroslyn — 12:58 AM
Philco 38-7 Oscillation
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 11:16 PM
Philco 38-7 Speaker
I know that when I first started working on this radio, I did not even have a speaker. Once I finally found one it was n...tludka — 11:00 PM
Philco 60 Squealing
I seem to remember eliminating a squeal by changing the IF frequency by a few KHz. Not that you should put too much tru...fenbach — 08:48 PM
Philco 42-390, code 121 speaker
These speakers pop up on eBay regularly, even if at bloated prices. Honestly, have not seen many parts on swapmeets.morzh — 08:38 PM
Philco 38-7 Speaker
The put-put is not like the speaker problem.morzh — 08:29 PM
Mission Bell Model 19A Car Radio
Hello everyone,  As mentioned in my last post I was going to see if the vibrator / rectifier section could be persuaded...Antipodal — 08:21 PM
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
