metal bezel
How to clean the metal bezel on a 39-25.  Bezel is just dull, what process is used for restoring to the original brilliance. How are the station call letters removed for cleaning, where can i get new call letter tabs?
Roger H.
Here's what I did:
https://philcoradio.com/phorum/showthread.php?tid=10018
...and here's where I learned it from:
https://www.youtube.com/watch?v=UeeViHNR...84&index=8
I suspect that it's plated steel and if you try to polish it you'll remove the plating. Damp cloth mild soap and dry. I didn't see anything for your particular set but I did see this https://philcoradio.com/library/index.ph...etter-kit/
Those escutcheons are brass I think, but try putting a magnet on it to make sure.
I suspect, ultrasonic bath with the aforementioned mild detergent or even acetone (if it is not paint) will do it good.
One way to replace the tabs is to print them on a P-touch printer with white-on-black tape. You may need to control it from a computer to get the font and size to be a good match to the original.
Hello guys,
I like Dale's idea I have both the label maker made by Dymo and Brother !
Anyway did you check to see if the was brass plating or not ?
Check out:
https://philcoradio.com/library/index.ph...on-labels/
These were originally for the 39-116, but I believe that the size of the tab, and lettering should be the same as yours. I photoshopped some for my 39 - 116 and printed them on presentation paper (thicker than regular copy paper) and they turned out great.
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM
There are currently 2526 online users. [Complete List]
» 1 Member(s) | 2525 Guest(s)
