Threads: 87
City: Pocatello
State, Province, Country: idaho
Klondike had some notes at one point about the restoration of a 42-322. Anyone know where they are?
The link I found doesn’t seem to work.
I’m specifically looking for details about dealing with the rewiring of the switch etc to deal with the hot chassis and power switch etc.
Threads: 291
City: Wilsonville
State, Province, Country: OR
Here's the
thread in the Phorum. and here's a
pdf of notes I made (the embedded pdf's in the notes are no longer active).
I don't think I talked about the switch but you can read through it. This was my first restoration so I didn't really know what I was doing
These sets usually had the neutral side of the power connected to the on-off switch and if I did anything I would have changed that so the hot side went directly to the switch.
Hope that helps.
Threads: 87
City: Pocatello
Thanks. This was quite helpful. I plan to put in a fuse as well as re-wire the power switch as you suggest along with a polarized plug. I’ll research this more and see what else I need to do from a safety perspective.
I only do these AA5 units once a year or so so I always have to look that up every time.
