Philco 84 antenna connection
Hello Everyone,
I was wondering what was the best way to connect an antenna for testing on my Philco 84. The field coil was bad and I found a replacement. I have never connnected these old sets up but see that there is an antenna and ground lug. I am not sure of the the wire type, loop arrangement, etc.
Regards,
Bob
I've used a single long wire up as high as possible and away obstacles. The gnd can be connected to a copper water pipe if your domicile doesn't use pvc pipe. Don't know that a loop would work very well w/this sell as it doesn't have a lot of gain.
From where I am I can pick stations up in CA and down in the Carolinas w/o a problem.
Now I think I've got it!
Very simply connect al long piece of wire to that contact for your antenna.   A piece 10 to plus 50 feet is no issue depending on the strength of the stations in your area.
Philco's: 86 Lowboy 90 Highboy 95 Highboy 76 Highboy 112X Console 118X Console 41-265 Console 41-608P Console 52GC 370 LZ 512 20 Baby Grand 70 Baby Grand 71B 52B 118B 60B 84B 610B 37-89B 38-10T 38-35B 41-221CI 42-321T 46-1203 48-214 48-206 49-506
Have a Philco 80 my long wire is app 30 feet, for a ground in my work shop have a ground rod that is used only for radios. If you installed a ground rod for your radios make sure it is 15 feet or more from the ground for the house electric. Enjoy your Philco 84. David
There are currently 3388 online users. [Complete List]
» 5 Member(s) | 3383 Guest(s)
AvatarAvatarAvatarAvatar
