42-345, question for an owner
Hello,
     I am working on a Philco 42-345.  It appears that there have been many hands inside this radio before me.  The tone control had been replaced at some time in the past, and I think it is wired incorrectly.  When the tone control is turned clockwise the bass increases.  This seems backwards from other radios I have had.  If the new tone pot was not wired correctly this would be the result.  The tone control is electrically wired correctly but depending on which end of the pot was used, the control function could be backwards.  I have not found a diagram or picture showing the mechanical connection to the tone pot.  If anyone on here has a functioning 42-345, could you check to see how your tone control works?  Does a clockwise turn of the control increase or decrease the bass?
Thank you for your time,
Noel.
Welcome to the Phorum, Noel! I don't have that radio, but I'm sure others will jump in with help. Take care and BE HEALTHY! Gary
It cannot be wired correctly and work incorrectly.
It is as simple as this: if you want to have you treble up and base down when turning clockwise, the upper (when looking at the pot from the shaft side, it will be the one on the right) pin of the pot should be the lower one on the sch, and the one connecting to the cap should be the left pin. That is, when you rotate clockwise, you want to GET AWAY from the GND, not get closer to it.
Best
Mike
Wow Mike, that's profound! That should be the Phorum motto.
Rod
Icon_lol
1. The schematic always work according to the wiring.
2. If the schematic does not work according to the wiring, see above.
3. The electronics is the science about bad contacts.
4. Most problems are either a contact where there should not be one, or the absence of a contact where there should be one.
Icon_lol
+1 for number 4 with an added theorem: The more connections in a circuit the higher the possibility of failure.
There are currently 2304 online users. [Complete List]
» 3 Member(s) | 2301 Guest(s)
