Does the 20 Deluxe use photofinish?
Threads: 11
City: Greenlawn
State, Province, Country: NY
Hi Pholks,
I fixed a Model 20 for a friend (Phriend? Am I carrying the Ph thing too far?) and received in payment a complete Model 20 Deluxe, with a good grille and the pie plate speaker with the spider that looks like a 45 record adaptor, so it sounds nice. Chassis needs resto, but I already have a good one on a bad cabinet. Problem is that someone painted the whole cabinet a rather yucky dirty blonde. Right over everything on the front, including the grille cloth the columns and the burl finish on the arch section, and on the sides and bottom moulding. I don't know if this is latex, some type of "antiquing" kit or, Heaven help us, spray paint
3 questions to start:
1. What is the best way to strip this? chemical? sanding? a combination? I can try the sides first as the side panel is cracked at the apex.
(My original cabinet is much worse.)
2. Is the fancy burl finish on the arch of the front panel natural or some kind of photofinish?
3. What are the best products for the face and sides? The "columns", the burl finish on the arch of the front panel?
Dunno when I am going to get around to this, but I have wanted a nice looking 20 Deluxe for a while.
Threads: 120
City: Omak
State, Province, Country: WA
Hello mr fixr,
I don'y think my deluxe is photofinish .
Threads: 572
No, it did not use photo-finish.
It is veneer with the shading on the front of changing darkness.
Threads: 269
I usually don't do any sanding till all the stripping is done. The veneer on the cabinet is thin and it is easy to sand thru it chemical is the way to go. After the stripping light sanding using a block on flat surfaces and just hand on the others is good to level the grain as the process tends to raise it. I don't use lower than 320G for this, 400G is good too but a little more work.
Citrustrip is a good start. It's easy to work with and you won't need a fireman's scott pack to get near your work. Some use steel wool I like scotch brite pads. Auto paint stores or ebay sell them the red and the grey ones are what you would get (a bit on the rougher side). And odorless mineral spirits (oms). You want the stuff in the metal can not in the plastic jug. The jug stuff is low voc and is worthless. This is used to cleanup the cabinet and get all the stripper off.
(This post was last modified: 10-15-2024, 10:52 AM by Radioroslyn.)
Threads: 572
Yeah, always wondered why they call them spirits "odorless".
It sure enough smell like a gas station.
Threads: 269
It's on a scale of how bad is it compared to... Naphtha, chlorine bleach, mek, and lacquer thinner it's odorless.
Threads: 47
City: Roseville, MN
I recently bought a can of oms and it now says Lo-odor mineral spirits.
When I use citrus stripper I leave it on for at least an hour, keeping it wet. You'll find it gives much better results than the recommended 20 minutes.
Threads: 16
City: Tulsa
When I stripped my 46-480, I used a tin of Klean Strip Premium Stripper (it comes in a blue aluminum tin shaped like a tin of lighter fluid), combined with grade 0 steel wool. I found that it was very gentle on the veneer while simultaneously being very effective at removing the finish. I wiped it all down with “odorless” mineral spirits afterward.
Joseph
Philco 46-480
Philco 49-906
Threads: 120
City: Omak
Hello Mr fixr,
You should have seen my Philco 610b which was painted with latex paint .
Here is a link to our Photo gallery that is my radio after restoring it.
https://philcoradio.com/gallery2/1936a/#Model_610B
Threads: 11
City: Greenlawn
Thx for the great info guys!!
Yes, keeping it wet works great; I I did that when I completely stripped my '64 Linc many years ago. Long drawn out process but was successful, the stripper I used back then even took off the Bondo and got me all the way to the bare metal from a body shop paint job over the Lincoln finish which consisted of Zn Chromate primer and red primer then the factory finish. Unfortunately after many years in primer, i will likely have to strip that off when I get around to finishing the bodywork on it, or sending it out. I don't remember what I used, but prolly too much to use on a radio.
philco predicta
Hi CGL,
Yes, troubleshoot the 140V Power supply, something is definitely loading it down, and since this supply excl...MrFixr55 — 07:32 AM |
1934 American Bosch 440T restore on YouTube
Looking forward to Part 2.Jimradio — 07:30 AM |
Yeah, looks really dense. It is amazing how many sets of brand A were made by Brand B. I have Mid 50s RCA that is an e...MrFixr55 — 10:15 PM |
Philco 60 Power Trans
I am not 100% sure of the reason, likely due to the depth of the winding, but on HV windings of a power transformer and ...MrFixr55 — 10:04 PM |
46-1213 Schematic Question
Hi Larry,
Great idea on the fuse! Place in the line at the power switch. Best between the cord and switch. While ...MrFixr55 — 09:59 PM |
Philco 47-205
Just picked up the second of the three Leatherette Philco's. (My second one in the three-radio series) Nice shape, all p...slford310 — 09:18 PM |
Dan;
I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM |
New find. 91X code 225
Hello,
I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM |
Hello,
The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM |
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM |
There are currently 993 online users. [Complete List] » 1 Member(s) | 992 Guest(s)
