American Bosch model 515.
Icon_problem Audio output transformer has open primary. output tube is a 42 and schematic about 3 watts+/- of power. any suggestions as to what I need to replace the transformer Icon_confused:
Pretty much any output transformer used with a another 42, a 6F6, 6V6,or even a 6BQ5 will work as a replacement, there are others of course but the plate impedance is pretty close between those tubes.
Icon_wave thank you for advise--will do.
Or if you want to live life on the edge you can use a 6.3v filament transformer. the 110v side goes to the plate circuit and the 6v side to the speaker.
Agree with all, you'll get some audio if everything else is OK. Then you can fine tune it and get a proper transformer
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
