RCA WV-98c
#31
strange. It should have more even to the GND, and the GND is 1M to the case.
#32
Are you saying if I measure ohms from the ground lead to case it should be 1m ohms? That low resistance tells me there is a leak to ground, right?
#33
Well, in the sch you provided (there is something missing at the very bottom, but I think it is GND), the sole connection to the case shown is the 1M resistor R31, which is used to bring the case and the GND under the same potential.
Unless I am missing something.
Of course there is a cap across that R31. And it could be bad. Or, again, we are missing something.
#34
I guess I need to look at r31 and C7.
That too.
There might be other things.
#36
Interesting readings, r31 common ground to case bounced to 1meg on analog meter, r31 common to case bounced to 1meg. R31=1meg.  Across c7, which is common to case with a parallel resistor = 40k ohms steady.
#37
My resistance readings are not even close. Worried about pins 1 and 6. Even though they are off, the meter works on dc 50v and higher.
#38
Would you re-read and correct?
This does not make sense.
#39
Check all your caps. Even ceramics. I am not sure what is going on.
#40
Just occurred to me: what if you have a power transformer leak? From a, say, secondary to the case. If it is bolted to teh case.
Not sure how to better check it.
#41
Thats a good thought but the secondary does go to ground via R30 27k resistor.
#42
Yes.....it would connect GND to case, and you do have 1MOhm.....
I am not sure how the wiper has resistance to the case.
#43
From now on iam using an analog meter. R31 removed is 1 meg and c7 .01 but chassis to common is 600k. Why is that?
#44
Are you saying the Chassis to GND became LESS when you removed the R31?
And we are sure the C7 and other caps are not leaking?
#45
Yep, hunting down the source. Will get back to you. Thanks
Looking for verification of correct schematic.
Klondike98, Thank you. I'll double check that SN and get back to you. GarySP, Thank you for the schematic.RossH — 12:13 AM
I think you have the correct take on your set. Ron's annotated early schematics that note the below B22000 serial numbe...klondike98 — 12:04 AM
Hello Ross. The Philco Radio Library located at the bottom of the page has the schematic with the tube count you have. ...GarySP — 10:48 PM
Tim It's be interesting if you put your schematic here. Who knows, you could get some advice from a few folks here. ...morzh — 10:01 PM
Philco 42-390, code 121 speaker
Thanks for that information. It would appear from the output transformer parts list that the transformer that was origi...Stevelog — 07:21 PM
I would like to verify that my thoughts are correct regarding my Model 70 and its appropriate schematic. My chassis inf...RossH — 06:26 PM
Welcome to the Phorum, Steve! The Philco Radio Library located at the bottom of the page has info on speakers and outpu...GarySP — 06:24 PM
I recently became the owner of a Philco console 42-390, saving it from the dumpster.  It is missing the speaker. It uses...Stevelog — 12:07 PM
Help identifying
Thanks for the welcome, Gary. There exists only one photo of the unit in the Richard Neutra-designed home. The photo (th...Davino — 10:54 AM
Help identifying
Welcome to the Phorum, Davino! Not much to go on from the above pictures. Would it be possible to take a photo or two ...GarySP — 10:25 AM
There are currently 1043 online users. [Complete List]
» 3 Member(s) | 1040 Guest(s)
