02-11-2025, 10:24 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group. You can be assured of not getting knockoffs
02-11-2025, 10:37 AM
I would check things around before simply replacing the transistor.
Something killef it. People who do not drink, do not smoke, do not eat red meat will one day feel really stupid lying there and dying from nothing.
02-11-2025, 10:40 AM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to kill it especially if the volume was up high!
Ron Bendix 0626. RCA 8BX5. RCA T64 Philco 41-250. Philco49-500 GE 201. Philco 39-25 Motorola 61X13. Philco 46-42 Crosley 52TQ Philco 37-116. Philco 70 AK 35 Philco 46-350 Philco 620B. Zenith Transoceanic B-600 Philco 60B. Majestic 50 Philco 52-944. AK 84
02-11-2025, 12:06 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test points. I'm really not sure why I don't have 10v at 19. There's just the one resistor at K5. I used to have 10v, but now it's 12. The only thing that changed was removing X6. I have no idea what happened to these before I got them. I'm trying to get one running for my cousin. He just got a 1965 Falcon and would like a radio. The guy he got the car from had these two radios, so no telling when they stopped working or why. I really appreciate everyone's help. Thank you.
02-11-2025, 07:33 PM
I'm a little befuddled on this one. Should X5 and X4 be tied together like this? It looks like someone added this at some point. I haven't removed them yet, I wanted to see what you thought before I did. It looks kind of funny to me.
02-11-2025, 09:24 PM
And I suspect whoever repaired it, wanted to re-use old transistors' pin stubs in order not to desolder them. I also suspect that if you look at the other side of the PCB, you might find delaminated/unglued traces. Inspect the whole thing, and try to stick to the schematic. People who do not drink, do not smoke, do not eat red meat will one day feel really stupid lying there and dying from nothing.
Yesterday, 01:25 PM
Thanks, will do.
9 hours ago
All need to go and be replaced. People who do not drink, do not smoke, do not eat red meat will one day feel really stupid lying there and dying from nothing.
8 hours ago
Quick progress report:
X7 is broken. Only one leg soldered, the other missing and the diode is cracked. I've replaced all of the electrolytics. C1 is confusing me. The parts list had two different values, but I can only find one C1 on the schematic. I have a 270uf in there now, I suppose I should change that to the 1000uf. Point 1 is 12.2v, point 2 is 10V, but everything else is 11.5v, not really sure why. I'll need to replace X6 and X7.
5 hours ago
If you are still on 5TPO, you lost me there. What X7? What Points 1 and 2?
« Next Oldest | Next Newest »
Users browsing this thread: brainfrz, 2 Guest(s) |
