Hi folks, I'm in the process of restoring a Philco 40-120C and I'm finding the wiring to be a bit puzzling. According to the schematic, the filament resistor should be connected to Pin 1 (the heater of the rectifier tube 35Y4). However, it is attached to Pin 5 (a "no connection" pin in the tube) without a jumper from Pin 5 to anywhere else. Meanwhile, Pin 1 is attached to Pin 6 of the 7C6 tube (the tube's triode cathode). It all appears to be the original wiring. Any guidance would be greatly appreciated. Thanks.
Let's try to sort it out. So we are working with the same info here's the schematic I have:
[Image: https://www.dropbox.com/scl/fi/mvw9qo0t7...xpxj&raw=1]
...and here's the pin out for the 35Y4 (only difference from the 35Z3 in the schematic is the center tap on the heater):
[Image: https://www.dropbox.com/scl/fi/xhbiio84h...3wc3&raw=1]
I agree that if the 132 ohm end of resistor #34 is connected to pin #5 of 35Y4 and there is no other connection to pin#5 (and no other connection to the end of resistor #34) the unit should not work. With all the tubes in place, what is the resistance reading across the power plug with the switch closed?
Is the tube in your radio actually 35Z3 or 35Y4, or something else?
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
