07-30-2011, 09:40 PM
Just got done recaping and adjusting IF and trimers dosen't seem sensitive as some of my other radios with tuned rf amps is that normal for a model 19b code 126?
model 19
07-31-2011, 08:52 AM
Should be as sensitive as your other radios. Start by checking the voltages on the tube pins, etc for anything out of range. May have a really weak tube somewhere. Signal injection may be needed if all else fails. Richard
07-31-2011, 10:20 AM
And don't forget those coils...they usually have, or develop, open primaries.
A model 19 should be a very sensitive, very good performing radio when properly restored. If you don't need a lot of audio power but want good sensitivity and selectivity, a model 19 or 89 is an excellent choice for a vintage radio. -- Ron Ramirez Ferdinand IN
07-31-2011, 05:06 PM
Already rewound two of the coils could be a weak tube tried the 80 and 42 out of my 84b no change don't have any 44 or 36 tubes to try radio works about like a good 5 tube radio like say a 37-610 but not as good as my sparton 1466 or GE SR II. I may buy a 36 and two 44 tubes to see if that helps
Thanks
07-31-2011, 05:16 PM
You could buy a tube tester.
Terry When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
07-31-2011, 06:30 PM
vinzer Wrote:Already rewound two of the coils Let's address that. How closely did you replicate the originals?
07-31-2011, 09:45 PM
Used to have a tube tester but gave it away last time we moved.
Counted the turns and wound them the same way as they were.
08-01-2011, 05:57 AM
vinzer Wrote:Counted the turns and wound them the same way as they were. Same wire gauge, same winding length?
08-02-2011, 09:14 PM
used same wire I used on a model 84 looked about same but don't the size.
Radio works ok just thought it could be a little better.
08-06-2011, 11:03 AM
Your windings may not be phased correctly; try reversing the leads to your rewound coils.
Before you buy more tubes, measure and record the voltages on your tube sockets and get back to us with the results; it can probably be narrowed down to a single component with voltage data. Do you have an oscilloscope? It will tell you quickly if your oscillator is running- and often it isn't. I love my 19; it's my most used radio at present. Pete AI2V
08-06-2011, 07:29 PM
I will check the voltages phase of coil wires and see what i find. Radio works so oscillator is running.
08-06-2011, 08:48 PM
Checked voltages found them all low . The lug that goes between the cardboard and filter cap was shorted to ground. Works much better now. Thanks for all the help.
« Next Oldest | Next Newest »
Users browsing this thread: 6 Guest(s) |
