Philco 89 indicator light.
Is there some trick to getting the indicator lamp evenly spaced between the frequency bands? Seems like no matter what I try the light is too far to the left. Seems to me it should be evenly spaced between the two.
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set screw on the drum to do that.
Dan
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its location.
Well thankfully that did not happen.
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
Sorry Murf, technical is what I do. OK, Unlike the Western Auto Tru-Tones, this True Tone is a Wells Gardner set. Th...MrFixr55 — 09:31 PM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
Testin a speaker and output transformer Trutone A2-G
Hey Murf, this shouldn't be too difficult if it happens all the time. I'm assuming this is the 1938 Wells Gardner A2 wit...RodB — 05:46 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
