I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye.
It has 13 tubes and the Marconi cabinets are always very nice. I will recap it .  It is a model 86.
Dan in Calgary
   Living in Calgary Alberta
Ooh, very nice!
Joseph
Philco 46-480
Philco 49-906
An imposing-looking radio, for sure.
My back hurts already, you could build a house with all the wood. Paul
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I'll bequeath them to a museum...
Dan;
I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's almost like they had the cabinets made up already, and at the last minute decided they wanted to use a slide rule dial on the chassis rather then an oval one. https://jproc.ca/marconi/home_ent/086_087.html Apparently the set has double conversion, and squelch, so you might want to go a little more in-depth then just recapping the set, also changing out any drifted resistors, and find someone who knows how to re-align a double conversion set.
Thanks Arran;
I don't even know what a double conversion is, but i do have a good friend In Nova Scotia
that would know.
So for now , need to get my neighbor to help me get it out of my truck.
It weighs as much as my Rogers 10-12.
Dan in Calgary
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
https://en.wikipedia.org/wiki/Superheter...conversion
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic to confirm. Basically you have two oscillators and two sets of IF transformers, set to different frequencies, it's to improved selectivity, and as MIke said to improve image rejection. Canadian Marconi used to build a lot of radios for military and commercial use, as well as domestic stuff, so they may have done this to create an economy of scale for production purposes. Some also have variable IF bandwidth, but unlike the Rogers sets it was done electrically rather then mechanically, as in the Rogers 10-12. I'm not surprised that the model 86 is heavy, the chassis has 13 tubes, and the cabinet is probably 1'' thick on the sides.
Icon_e_biggrin What a behemoth!  I hope the final result is as much a quality sounding example!  Keep us posted on your progress.  Take care and BE HEALTHY!   Gary
>>What a behemoth!
A Juggernaut.
A backbreaker.....Paul
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philco "...boys" with pan chassis even come close. My wife and I were carrying it together, and she dropped it. This is about twice the weight. I have it for over 10 years, and still have not been able to take upon it.
One day, shouild I live long enough, one day...
May be a backbreaker but with 2 6L6s and a 5Z3 rectifier, this thing should ROCK!
The schematic is on RadioMuseum I have a copy.
I still have the Marconi  in the garage and have not taken the chassis out yet. I have a couple of others ahead of it as far as recapping is concerned.thanks for the raplys
 Dan in Calgary.  PS I am still looking for knobs for this radio.
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
Peter; The Philco (3)16X was likely a Canadian market Philco, which means that Philco Products of Canada LTD likely h...Arran — 07:45 PM
It is kinda impossible for the plate to have 120V with the tube in and have it not with the tube out, short of the tube ...morzh — 07:42 PM
In case anyone else run into the issue I had figuring out Richey caps I received a response from just radios, and the ne...osanders0311 — 05:07 PM
About all I've done is unplugged them to take the chassis to my workbench. Anything I should check with them?sq65 — 04:13 PM
Have you touched the speaker wires, either speaker plug or the socket?morzh — 03:47 PM
Jonnym
Thanks everyone, I will pull the chassis out of the cabinet and do some checking.    The volume adjustment is not “scra...Jonnym — 02:01 PM
Model 96 volume control
Welcome to the Phorum! :wave: ...and in addition to the annotated schematic that Mike linked to there is the fact...klondike98 — 01:27 PM
Hello, I have a 46-1209 I am restoring. I was always told the radio didn't work, however when I got it home and powered ...sq65 — 12:18 PM
There are currently 942 online users. [Complete List]
» 2 Member(s) | 940 Guest(s)
