Well, in the declining years folks sometimes tend to use what disposable income they have left to pamper themselves to their youth's dreams which they had no money when they were young and no time when they were mature.
After all money is not to be taken to the grave, so why not treat oneself to one or two luxuries that we salivated all over in our teens...
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small axial ones.
So, I think, I will use the 10mH one; it is about 47 Ohm (which I think is not even important) and about 40mA (which is way more than I need there).
Today I could not do anything: came home, cook the meal, took out the recycling (ours is every other week, so it is lots of it), called mom...by then it was already 8pm.
Not today, no...
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I took off was 0.08 to 0.09mm.
I took AWG 38 I have, which is 0.09 to 0.1mm, and in 30 minutes or so put manually 580 turns (it was 700). Condisdering this is a filter choke, this should be just fine.
I took the ohhmeter to it, and it gave me 64-65 Ohm (66 is the target), so that was right on, and the inductance on my LCR was 5.2mH (my first calculated value on one of the inductance calculator was 6mH).
So it is just fine.
I took a candle and heatgun and potted the open wire.
Tomorrow I will connect it back and try to power up.
Hello mike,
Nice job hopefully it works and I am sure it will.
Mike;
Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the power output stage that that they often had an RF choke involved to prevent IF interference from getting into the audio (at least it think that was what it was for). Sets that had a proper second detector diode, or pair of diodes didn't need it so much.
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
There are currently 3141 online users. [Complete List]
» 1 Member(s) | 3140 Guest(s)
