Canadian Philco 37-361
How many Bakelite  blocks does a Canadian Philco   model 37-361 have ?
 I might be doing a restoration on one
Thanks
 Dan in Calgary
   Living in Calgary Alberta
Dan;
  I don't think that there are that many if the Toronto plant followed what they did in Philadelphia, probably the power line cap is a Bakelite block but not much else. Most of the Canadian models shared chassis with their U.S cousins up until 1939-40, though the cabinets differed sometimes, like my model 3118B. They are not really that had to restuff if you have to, Mike/Morzh has the technique right down.
Thanks for the information. I don't have the radio yet,but i wanted to get some information
 Dan in Calgary
Hi Jeffcon, First off, Welcome to the Philco Phorum!, a Phamily Phriendly Phorum, Phull of Phine Phriendly Pholks and ...MrFixr55 — 07:53 AM
+1 on what Morzh and Rod said, do the caps first. I only supplied the type and replacement numbers because in your first...462ron — 07:26 AM
Philco 370LZ chair side not a 71LZ
I came across this post and I just redid my 370. My Question is: Where does the toner rod go. This one was in a bag a...Villager61 — 08:36 PM
My collection presentation
This will be a description of my twice favorite part of the collection. First, these are my favorite battery radios. S...Vlad95 — 06:25 PM
You probably don't have to worry about replacing transistors until you finish the recap. If you find that a transistor s...RodB — 10:19 AM
Start with recap. Address transistors only if needed. Testing transistors is simple and is best done with an analog ohmm...morzh — 09:01 AM
Hi Jeffcon, your HR-101 transistors cross reference over to an ECG-104 or RCA SK 3719 or an NTE104. It’s a PNP Ge (germa...462ron — 08:27 AM
Thanks RodB and morzh, Am I using incorrect terminology regarding output transistor question whether they’re NPN or PNP?...Jeffcon — 08:56 PM
Full recap is a no-brainer. By full I mean full. No caps, with the sole exclusion being ceramics/mica, if present, shou...morzh — 03:57 PM
This article has been updated. A tutorial on capacitor restoration has been added. How to repack an electrolytic cap...Vlad95 — 11:43 AM
There are currently 1641 online users. [Complete List]
» 3 Member(s) | 1638 Guest(s)
