03-09-2025, 01:29 PM
I’m currently recapping this National NC/57. This has a scratch on the case. I guess I can sand this out and just do a small touchup.
National NC-57 case
03-10-2025, 05:09 AM
Not only is the paint chipped out but it has dent that will need to be pushed, or pounded out. The set must have been dropped, and landed on the band switch knob, hopefully pushing the knob back, and denting the cabinet is the extent of the damage.
Regards Arran
03-10-2025, 05:27 PM
Yea. I think a repaint is order.
I probably have a spare bandswitch knob somewhere. Since this is an AA-5 type design I plan to drop a Triad x35 isolation transformer in this. The other design element I want to change is add some connectors so you can easily remove the speaker. As I’m reading this the filter choke goes to the pins 3 and 4 of the 6V6 audio output tube. Running two wires topside on the chassis will make that easier. At some point the speaker dies - that way it can be replaced without taking the chassis off. I’m debating replacing the dials. Reproductions are available, but I’d have to get a rivet tool.
03-10-2025, 05:35 PM
As far as the cabinet condition, try cleaning it with Goop (non-pumice) hand cleaner and 0000 steel wool. GENTLY! You'll be amazed how much dirt will come off. Wipe it down with soft rags. It will still have some battle scars, but a lot of the smudges should come off. At this point what is there to lose? - Gary
"Don't pity the dead, pity the living, above all, those living without love." Professor Albus Dumbledore Gary - Westland Michigan
03-10-2025, 05:54 PM
I have some of that so I’ll try it. That works great on my Philcos. This radio was a gift from a friend of mine so I’m trying to make
I’m trying to find if there’s a readily available grey paint that matches.
03-11-2025, 01:21 PM
For that dent, if it's easy to get to both sides of the sheet metal place hardwood or metal shims on both sides of the dent then lock them together with C-clamps, or better still, a vise. It nay press the dent back out. Luckily there didn't seem to be any creases, just an indent. Let it sit overnight. Just like my last comment... At this point, what is there to lose. Take care and BE HEALTHY! Gary
Yesterday, 12:30 PM
It looks like it didn’t dent the metal. Using 0000 steel wool should clean up the front.
I’ve found this Winter Grey gloss paint. Not an exact match but it will work. The labels are actually incised in the metal. So I’m thinking I can paint the case and then use a white lacquer stick on the letters.
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
