Philco 680 restoration - info needed
A fellow collector is restoring Philco-680 console. It is in poor shape, both, inside and outside. Some items are missing, like output transformer - N 158 on the schematics - item 32-7461 and interstage tranfromer - N 157, item 32-7446. Schematics suggests resistance, but not other information, like wire diameter or number of coils. Any information of this kind, pictures etc would be greately appreciated.
Thank you in advance!
Leonid
Hello, Leonid: glad to see you made it here to the Phorum.
I will check my parts chassis that I have to see if I have any of the items you are looking for.
The Philco Repair Bench site is another good place to start for schematics and other info about the 680
Hi,
Unfortunately, Philco did not give the information you seek (number of turns of transformer windings, wire size, etc.).
TA Forbes Wrote:Hello, Leonid: glad to see you made it here to the Phorum.
Tom, schematics is available.
I'll check Repair Bench.
Leonid
Yes, I have the full service info for that killer 1936 set.
Chuck
38-10T chassis Restoration begins
Rich do you dunk the whole razor in there with it turned on to get a good mix? :lol:dconant — 04:48 PM
Rusty Tuning Condenser
David, RodB says to watch out for pot metal as it might dissolve in vinegar. I think there might be some in there. I thi...dconant — 04:40 PM
Give the tuner a good wash in Dawn and hot water. Then set tuner in a plastic container and cover with vinegar let soak ...David — 12:53 PM
If you have rust between the vanes, I wonder how you get the NJ in between, and how you then wipe it off.morzh — 12:02 PM
Philco 60 Squealing
If the noise is still there, the OPT might just be OK. Or so we hope.morzh — 12:01 PM
Philco 60 Squealing
You would probably be replacing the OPT.RodB — 10:54 AM
Philco 60 Squealing
I have been playing the radio for a while now and doing well. Turned it on today and all I got was a whole lot of noise....dconant — 09:39 AM
Thanks guys. I think I'll give the Naval Jelly a try since I can better control where it goes.dconant — 09:23 AM
Philco Model 80 Transformer resistance
Just forget this number, it is useless anyway. Simply proceed with your project.morzh — 10:08 PM
My $0.02 is that it is a misprint. I tried to look up the value for the similar 84 and 37-84, and ther is no resistance...MrFixr55 — 09:51 PM
There are currently 3119 online users. [Complete List]
» 2 Member(s) | 3117 Guest(s)
