Replacing NTC resistor in Philco 52-940
There is a negative temperature coefficient resistor/filament dropping resistor used in the model 52-940 AC/DC set. It's rated at 100 ohms, but I believe this is a resistor that has a cold-hot resistance-also known as " globars". I've read elsewhere that the CL-90 inrush current limiter is the replacement for this. What are the correct replacement options?
Just a suggestion. I have never tried it. If the globar is open replace it with a 100 ohm 10 watt resistor and add a CL-90 in series with the On/off switch. Another possibility is to replace the 35L6 with a 50L6 and do away with the 100 ohm globar and still add a CL-90 in series with the on/off switch to prolong the life of the tube filaments.
I have used a CL-90 in AA5 sets without any original surge resistor protection eg. a Emerson 503. It drops 4-5 volts and increases warm up time to about 30 seconds. In general I usuallly add a CL-90 to all the sets that I restore just to prolong tube life. It's kind of neat to watch the pilot light ramp up to full brightness. Icon_smile Mount the CL-90 so there is as much clearance as possible to other components, particularly electrolytics. CL-90s get hot. That is how they work. Mouser has CL-90s and does not have a minimum order charge.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
