Threads: 28
City: Tulsa
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inputs on my oscilloscope, and I do not have control over amplitude or DC offset. I’ll have to open it up later tonight. Fingers crossed that it’s not a total loss, but at least it was a dirt cheap oscilloscope!
Rookie mistakes were definitely made. I had started out using a capacitor (as the instructions do indicate), but it kept falling out of the alligator clip on my probe and I grew frustrated. I figured what the heck, I’ve got the radio connected to an isolation transformer. But I failed to consider the DC voltage I might introduce to my signal generator.
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Threads: 54
City: Shenandoah,
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor!
Ron
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 28
City: Tulsa
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I used it to trace the signal on its own circuit board. I checked the signal generator output, the resistors and capacitors, the op amp, etc. but no signs of a signal. I traced everything back to the DSP IC and gave up at that. I ended up buying an identical oscilloscope with arbitrary waveform generator on Amazon. It’s a Hantek DSO2D15. For the price, it is surprisingly feature rich. The oscilloscope is rated for signals up to 150 MHz, and the signal generator can produce an arbitrary waveform (including AM and FM modulated waves) at frequencies up to 25 MHz. This enables me to produce AM and FM IF signals for alignment. For FM RF signals I can use one of those automobile Bluetooth-to-radio transmitters.
I shopped around quite a bit. I know people online tend to harshly review the Hantek equipment (bug prone, tend to lock up, etc.) but that hasn’t been my own experience. Anyway, I looked at Rigol, Siglent, and others. I couldn’t find a model with built in signal generation below the $500 price point. Even when browsing dedicated signal generators, I was easily looking at spending $300 on one of the frontline models. For me, the Hantek was a no-brainer. I couldn’t justify the higher prices for a unit I use on perhaps five projects a year. The new unit should arrive on Monday, and I can reattempt alignment with a capacitor connected to the signal generator output this time!
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Threads: 28
City: Tulsa
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some trouble in the RF section though—I can’t receive AM, shortwave, or FM RF signals. The alignment procedures for the RF section don’t seem to be working.
Either I have a bad 7F8 converter tube or I have a miswire in the RF chassis. I will first assume a miswire, so I will comb back through to make sure everything matches the schematic. If it does, I’ll replace the tube.
I can feed an AM signal at 455kHz to a loop antenna sitting just beside the loop in the cabinet, and the radio picks it up and passes it through to be demodulated. But I can’t do the same for a signal in the AM bandwidth.
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Threads: 23
City: Greenlawn
State, Province, Country: NY
Hi Joseph,
First, verify that your band selector is in the correct position for what you want to do. I believe that the first position is the tuning buttons. If no position works, I think that the oscillator is dead. Do recheck your wiring. If this set has a separate RF chassis, it may be tight there. Of course, the tube could be bad also.
Threads: 28
City: Tulsa
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets. I verified my position for the band switch but no luck. I’ll verify the wiring tomorrow evening. If there are no errors, I’ll replace the tube.
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Threads: 23
City: Greenlawn
Hi Joseph,
Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity checks. I don't know why she feels this way. I only have about 80 radios, 15 stereos and 12 TV sets. That's not too much, is it?
Threads: 28
City: Tulsa
Not too much at all!  Sounds like you’re just dabbling into the hobby!
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Mr. Fixr
Compared to you I am sooo green behibd the ears...I have about 40 or so sets.
Threads: 28
City: Tulsa
I’m making progress with the alignment. It was a combination of needing to solder the connection on pin 3 of the BC oscillator coil (oops!) and needing to replace the 7F8 tube. Luckily I had a spare 7F8 in the 48-482 I have sitting in my attic.
Here’s a couple of links to videos demonstrating AM and FM. Haven’t picked up anything on shortwave just yet. I still need to finish up with alignment of the RF section, but this is so exciting after eight months of work!
https://youtube.com/shorts/wpDEIsRydR8?s...37rEL9TApC
https://youtube.com/shorts/4ATUTwN2IN0?s...Dc1KLdPuLo
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Threads: 23
City: Greenlawn
Throw in all the Audio equipment that has to be kept in a bedroom (my office)L. 8 portable self contained PA speakers, road case containing mixer and two 4 channel wireless mic receivers. Throw in a large bin containing cables, mics, other paraphernalia. 4 speaker stands, 8 mic stands under the bed of the other bedroom.
Of the 80 radios, 35 were either from childhood or street finds. The rest were from eBay. All of the stereo equipment except for the KLH and all of the TVs were either "gifts" from family, friends and neighbors, or street finds, including the 2 Fishers (400 and 800). Yes, Ms. Fixer does put up with a lot but it keeps me off the street and out of trouble.
The vast majority of the radios work and were repaired by me. The TVs will take more time.
Threads: 226
City: Omak
State, Province, Country: WA
Hello MrFixr55,
That will for sure keep you out of trouble!
Last Sunday was spent mostly doing yard work anyway the weather is starting to get nice here so between working on the house and yard.
I do have some radio cabinet work to get done too plus some other things like car shows and meets , my summer will be busy.
I will be doing some more changes to my sprinkler system too .
Threads: 28
City: Tulsa
Wow, here I am with only two restored radios. I’ve got to boost those numbers! If you can’t run with the big dogs, you might as well stay on the porch.
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Threads: 23
City: Greenlawn
Joseph, it is because I am retired and a little demented. My problem is that I wanted to own a collection that spans the history of radio, but my house is only 1,000 Sq ft (not counting basement and garage). My office is about 8'X10'. Shelving helps. I do have some duplicates. I have some of the first radios marketed for broadcast reception (The Westinghouse Aeriola Sr and "RC", both of which date to about 1922, an Atwater Kent 10, a GE built RCA Radiola 2, a FADA 160 and a homebrew 3 tube regenerative receiver, likely ca 1923). My only goal now is to get an RCA Crystal set (Radiola 1, Aeriola Jr, etc.,) a GE 1300 and 1400
ca 1921, and an RCA R37, ca 1933, as this is the archetype of the "modern" or "mature" tube radio containing a pentagrid convertor, remote cutoff pentode IF, diode- triode or diode-pentode detector - 1st AF amp and pentode output with heater - cathode design, and AVC derived from the detector. Other than heater voltage, tube style and the elimination of the power transformer, this circuit remained essentially the same until the end of the vacuum tube era. The "AA5" or "All American 5" AC-DC radio derived from this circuit (although the R37 is a 6 tube set that has an RF amp also). This set uses tubes with 2.5V heaters. At this time, Philco used 6V heaters because Philco was a leader in automobile radios. It was thought that operating 6V tubes on AC would cause too much hum but this turned out to be not the case. I may also want an RCA 128 as it was the epitome of "Skyscraper" styling.
I have nothing from the "Wireless" error but hey, I'm not rich.
You have just the right amount of it. No perfectly sane person will collect that junk that we do.
| Hello Everyone,
There are currently 1902 online users. [Complete List] » 1 Member(s) | 1901 Guest(s)
