Atwater Kent 708 Flexible Resistor Identification Needed
Hello Everyone,
I am in the process of rebuilding the sub-chassis in an Atwater Kent 708 radio serial number 4796904 and I am having a problem identifying the four flexible resistors. The schematic that I found online has a different arrangement and shows only three flexible resistors. If someone could please supply a diagram that is the match for my model and showing the resistor values I would appreciate it.
The diagram I have drawn up shows the four resistors in different colors. The red one checks at 200 ohms and the green is 432 ohms. The blue and purple resistors on the lower left side of the diagram are both open and the values for these are what I am searching for. Thank you.
According scematic in "Rider volume" #4 page 17
Green - R1 425 ohms (corresponded your measurement)
Blue - R9 2000 ohms
Purple - R11 800 ohms
But in this scematic not present red resistor. But any way values above look like rasonable and very near from neccessary.
You can temporary soldering test resisters and adjust its for best result. And then search and bay original wire resistors with determinated values.
Hello,
That diagram in Rider's is a little different from the setup that I have. Note that the R11 resistor connects to ground and the one in my radio connects to the choke. R1 and R9 look correct though.
http://www.nostalgiaair.org/PagesByModel...001471.pdf
Have you looked in here?
http://www.nostalgiaair.org/PagesByModel...001472.pdf
And in here. 708, 808 and 808A are very similar.
morzh
You are right. Scematic 808 is corresponded requered.
On this case
Purple - R11A 160 ohms
Red - R11B 160 ohms
But red according scematic connected from chok to 2nd I.F.
On picture look lile mistake that it going to ground istead  2nd I.F.
808 scematic present in "Rider volume" #5 page 42
None of the diagrams that are shown online are the same as what I have drawn. It is my setup with the two resistors connected to the choke that I cannot find.
Tony
Could you possibly trace the flexes to where they go in your chassis?
Should'nt be too hard.
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
Hello Keith! I've updated your thread with the proper model number. Take care, - GaryGarySP — 01:10 PM
Value of capacitor
Why are you having to replace it? Does it measure out of tolerance? Is it mechanically damaged?DaleHCook — 07:50 AM
Hi Keith, here is the official Philco service info found in the Philco Library under service info……https://philcoradio.c...462ron — 07:23 AM
My collection presentation
This article has been completely updated and finished. The beginning of a portable collection.Vlad95 — 11:49 PM
Philco 50-295 antenna connections
Thanks Rod, That makes perfect sense. Is there a way to edit my post? It's a Philco 50-925 and not a Philco 50-295. D...keith49vj3 — 09:55 PM
C is for an external speaker.RodB — 08:39 PM
Philco 370LZ chair side not a 71LZ
Can you send a couple of pictures?slford310 — 07:11 PM
There are currently 1266 online users. [Complete List]
» 1 Member(s) | 1265 Guest(s)
