Philco Battery-WWII vintage
We received an inquiry from a metal detecting group who was at a WWII site. They unearthed the Philco battery you see in the photos and were curious about it. I told them of Philco's early battery history and of the switch to military gear production during the war. I suspect this battery powered one of the wartime pieces of equipment. Does anyone have any other specific info about this that we could share with the group?
Relevant Links:
From our History page: https://philcoradio.com/library/index.ph...n-and-war/
From our Library, a 1942 annual report with wartime production discussion: https://philcoradio.com/library/index.ph...al-report/
From Library, 1944 Army Navy Philco Service: https://philcoradio.com/library/index.ph...ce-ca1944/
1944 Philco Ordnance for Victory brochure: https://philcoradio.com/library/index.ph...t-booklet/
Probably not relevant to this battery but WWII related, Radar on Wings: https://philcoradio.com/library/index.ph...tion-1945/
Philco display during WWII: https://philcoradio.com/library/index.ph...ring-wwii/
Another dislplay photo during WWII: https://philcoradio.com/library/index.ph...ing-wwii2/
Scaled to the persons foot in photo safe to safe that's a big one. I am sure there was all kinds of war materials they provided.
While a kid, in our garage there was a 12V Lead-Acid battery from T54 tank.
This job was probably 150 lbs or so, ad was 3 times longer than a battery taht would go into a Jeep Cherokee (those were much larger than the modern Japanese jobs).
We used it to start the car in winters when the battery inside the car would get anemic.
Well Philco did start out in the lead acid battery manufacturing business, and I think that they were still doing so during the war. The two materials of choice for battery cases used to be vulcanized rubber, and glass, even so that one is in decent shape for being buried in the ground for who knows how long. It could have been used as an aircraft battery, or even in a submarine, it's a 12 volt unit regardless, each cell being 2 volts.
Mike;
I have no doubt that a battery for a T54 would have been a big one, most of those Soviet tanks were Diesel powered so they needed a lot of cold cranking amps to turn the engine over.
Yep.
It had handles on either side, and it took two reasonably strong men to carry it.
We had that Soviet FIAT 500 clone for a car, and starting it on a cold winter morning (and we lived in Southern Russia!) took some doing.
The car's own battery (and we had serviceable ones, where you measure the electrolyte specific gravity and add distilled water if needed etc) would get farly anaemic, and so the tank battery would get hooked up.
Sometimes, as that extra help, some oild would have to be drained, put in a tea kettle (we had an old aluminum one dedicated specifically to this) and set on a gas stove to make it hot; then it would get poured right back, and then thet car would get cranked.
Imagine several morning in a row like this, after you get up and are ready to go to work.
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "cold cranking" amps.  There are 3 cells with external bus bars connecting them.  Apparently, they brought out more than 1 pair of terminals for each 2V cell and the bus bars parallel these cells. If used for high current applications, I suspect that the battery was placed in series with other batteries.  I am not sure but I believe that many military vehicles were either 12V or 24V as many of the vehicle mounted radio equipment was designed for either 12V or 24V DC.
I can't read the lettering on the battery.  If specifically for the military, there would be a "boilerplate" stating the government agency contracting for the battery, the manufacturer and the contact number, as well as the nomenclature for the part, such as Battery, Storage, 6V 180 AH or similar to that.
The case may be "pitch".
Where is this "WWII Site"?  They did the environment a favor by unearthing the battery.  However, they need to be careful as there may be toxic or explosive material on site.
Yes, the original name for Philco was the Philadelphia Storage Battery Company.  Their second iteration.  Prior to the name change to Philadelphia Storage Battery Company, they were the Helios Electric Company, manufacturing carbon arc lamps, which preceded incandescent lamps.
From Wikipedia:
Philco was founded in 1892 as Helios Electric Company.[6] From its inception until 1904, the company manufactured carbon-arc lamps. As this line of business slowly floundered over the last decade of the 19th century, the firm experienced increasingly difficult times. As the Philadelphia Storage Battery Company, in 1906 it began making batteries for electric vehicles. They later supplied home charging batteries to the infant radio industry. The Philco brand name appeared in 1919.[7]
The rest is history.  After manufacturing batteries, chargers and "B" Battery eliminators, Philco started manufacturing radios of the TRF type, and eventually Superhets.  The Model 20 was a watershed model that helped place Philco in first place in radio sales for many years, and initiated the "Cathedral" radio style.
More can be learned about Philco from the History tab in our own Philco Library.  Click the Philco Library tab on our website home page, then click History.
A link is here:
History – Philco Library
Below is a link to Chapter 4, "Diversification and War" from the History section of the Philco Library:
The most important products made by Philco during WWII were Radar instruments and proximity fuses, but Philco manufactured other military materials such as vacuum tubes, CRTs, wave meters and even filing cabinets.  The Storage Battery division was still in business in Trenton, NJ, so it is possible that Philco was producing batteries for the military, as well as for civilian use.
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
Sorry Murf, technical is what I do. OK, Unlike the Western Auto Tru-Tones, this True Tone is a Wells Gardner set. Th...MrFixr55 — 09:31 PM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
Testin a speaker and output transformer Trutone A2-G
Hey Murf, this shouldn't be too difficult if it happens all the time. I'm assuming this is the 1938 Wells Gardner A2 wit...RodB — 05:46 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
There are currently 596 online users. [Complete List]
» 2 Member(s) | 594 Guest(s)
