Replacing NTC resistor in Philco 52-940
There is a negative temperature coefficient resistor/filament dropping resistor used in the model 52-940 AC/DC set. It's rated at 100 ohms, but I believe this is a resistor that has a cold-hot resistance-also known as " globars". I've read elsewhere that the CL-90 inrush current limiter is the replacement for this. What are the correct replacement options?
Just a suggestion. I have never tried it. If the globar is open replace it with a 100 ohm 10 watt resistor and add a CL-90 in series with the On/off switch. Another possibility is to replace the 35L6 with a 50L6 and do away with the 100 ohm globar and still add a CL-90 in series with the on/off switch to prolong the life of the tube filaments.
I have used a CL-90 in AA5 sets without any original surge resistor protection eg. a Emerson 503. It drops 4-5 volts and increases warm up time to about 30 seconds. In general I usuallly add a CL-90 to all the sets that I restore just to prolong tube life. It's kind of neat to watch the pilot light ramp up to full brightness. Icon_smile Mount the CL-90 so there is as much clearance as possible to other components, particularly electrolytics. CL-90s get hot. That is how they work. Mouser has CL-90s and does not have a minimum order charge.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
