Rogers Majestic R-646
Hello Vlad. In general, in my opinion, restoring a wooden case, even in such a bad condition, is much more pleasant than restoring a chassis that is too dirty and rusty. Icon_wink Washing the chassis and cleaning it of rust is the most unpleasant procedure for me, so never expect a perfectly clean chassis from me. Icon_mrgreen But repairing the receiver case is a real pleasure. In my opinion, there will not be too many problems with your cabinet in terms of reproduction. First, you need to glue it and remove the old layer of varnish, and then it will become clear what materials are best to restore it with.
Ретро радіо музей ТБ. Antique Radio MuseumTV
Sincerely Peter
З повагою Петро
Since the original schematic was in an old unreadable style, I created a new schematic diagram.
Owners of this radio can use it.
The original schematic is also attached for reference.
If you want to work, lie down and sleep, and everything will pass.
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power transformer looks alive.
2) The speaker and field coil are alive.
3) The primary power capacitors C21, C22 are alive.
4) The power choke is OK.
5) All resistors are within normal limits.
6) All mica capacitors are within normal limits.
7) All lamps are most likely alive.
The second negative news:
1) All electrolytic capacitors C 8, 9,10,11,14,16,18 are dead (maybe not all, but I will still change them (repack).
2) Both potentiometers R11, R14 are broken (open or poor contact). I will try to restore them.
3) Most of the wires have cracked insulation and require replacement.
The third and very sad news:
Both audio transformers are broken.
I'll try to rewind it, but the phase inverter transformer can have over 10,000 turns in each coil, and the wire is less than 0.08 mm
It will be a terrible job to rewind. The output transformer is a little easier, but not much.
In the end, I'll probably start with restoring the case, and in parallel, step by step, I'll restore the circuit parts and chasis
Oh-oh-oh
  Icon_cry
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
