Model 39-6C, undocumented variant
I saw this in the Philco gallery of photos.I'm wondering if anyone knows anything about this version. I recently found one in very good condition.There are a few small scratches on it & the finish looks original with a little wear around the on/off-volume. The chassis is super clean. It was partially re-capped years ago.
I own one, what exactly do you need to know?
Hi Ron,
I like to know how many of these were produced,if they are rare,and what was the original grille cloth pattern. Mine has the #14 that was glued and held down with the speaker cut out,then staple gunned with a regular width sized staple. The plastic dial window is stapled with the small staples.
We don't know how many were made; it is not documented in Philco Furniture History, an in-house, unpublished Philco document which lists and pictures (almost) all of their radio cabinets. This is why I have listed it as an undocumented variant - there currently is no known documentation on this variant.
I wouldn't call them rare - I would call them uncommon.
Mine also has the Philco "Ribbed" cloth (#14, now only available at Antique Electronic Supply for a limited time as S-G440 and S-G440F). The grille cloth was glued to a thin backing board, and stapled into the cabinet. The dial cover was also stapled into the cabinet.
Does yours have a yellow sticker in the back which reads, among other things, "MODEL 39-6" with no mention of Philco? Mine does. I suspect these variants were made by Simplex, but I don't have any documentation to prove that theory.
Ron,
I do have the yellow stickers, the model # 39-6C is on the upper sticker. The lower has the tube layout.No mention of Philco anywhere on this radio. The stickers are in excellent condition. If you would like a picture,that would be no problem.
Thank you for your expertise.
Sure, photos are always welcome here. Icon_smile I'll also post a couple pix of mine if I get a chance to do so.
Does the finish look original? Notice the wear through around the volume knob. I'm debating about refinishing it. The sides have a few scratches.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Yup, Jimmy, your 39-6 looks identical to my set; mine has the same stickers inside the cabinet, also.
You might be able to get away with a selective refinish; that is, just lightly wet sand the area around the volume control, spray one coat of Medium Walnut toner, a few coats of clear, and then carefully rub it out. I did that on the top of my 39-6 as it looked good overall but had a blemish on top. It looks OK now.
Ron,Thank you for the information. I'm going to use this set Friday to listen to tube talk. When I get some extra time Icon_rolleyes ,I'll work on the finish.
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
There are currently 831 online users. [Complete List]
» 2 Member(s) | 829 Guest(s)
