Code 121 vs Code 125
Hi everyone; I'm a new member to this site and I have a problem getting a proper set of schematics (even from Riders) !!!
Example: I really liked the Philco 48-200 and I purchased a couple of them because I was looking at a Riders schematic and it has some really good troubleshooting specs. What I didn't realize was that the schematic and the troubleshooting guide is for the 48-200 Code 125 and my 2 sets are Code 121. The 35Y4 and 50L6GT are strictly for use in a Code 125 set and are replaced with a 35Z5GT and a 50A5 in a Code 121 set. Since the pins are different that means the schematics are different for the Code 125 and the Code 121.
It appears as if there are a lot more Code 121 sets in existence than there are Code 125's. So why did Riders not draw up a set of schematics for the Code 121 sets instead of just indicating the tube changes on the Code 125 schematics ???? This problem occurs on a lot of the Philco sets during the 1940's ans 50's.
Anyway I have seen a schematic of a 48-200 Code 121 (with the 35Z5 and 50A5) somewhere in the past and my other question is: where can I find the proper Philco schematics with the Code 121 ?????
Thanks;
Andy
winniefs Wrote:It appears as if there are a lot more Code 121 sets in existence than there are Code 125's. So why did Riders not draw up a set of schematics for the Code 121 sets instead of just indicating the tube changes on the Code 125 schematics ???? This problem occurs on a lot of the Philco sets during the 1940's ans 50's.
Thanks;
Andy
Hi Andy,
Rider's only printed the schematics that were submitted to them. In some cases the code change might have only been something in text. Chuck Schwark here might be the best possibility of having something that you need.
GL,
Bill
Well a 50A5 is basically a loctal version of a 50L6 so the pin out is a little different but they are electrically the same. The 35Y4 is basically the octal version of a 35Z5. It shouldn't be too difficult to sort out by using a tube manual. It's very likely that the two tube changes were the only difference they made to the circuit between the two codes, otherwise there would be more documentation, did Riders show the changes made with a sub diagram? What I find strange is why there is a code 121 and a code 125 but nothing inbetween, most have a code 121 and then a code 122 but they didn't always do that for some reason.
... and why don't they have codes 1 to 120 either?
-Mars
The codes 1 to 120 were sold to Zenith, who re badged them as Waltons tombstones. That's why they are so popular.
Now you know the rest of the story.
really?
-Mars
Yep. Icon_wink
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
There are currently 2295 online users. [Complete List]
» 1 Member(s) | 2294 Guest(s)
