How to make a glass scale
Threads: 7
City: SPRUCE GROVE
State, Province, Country: Alberta
All radio receivers, from the very beginning, have been indispensable without a dial. This component was, in principle, required to be present in one form or another in every radio. Of course, we're talking about ordinary household appliances, not radios in general, which could include quite specific devices. The simplest example would be radio receivers with fixed channels.
For us in this topic, we're interested in how to restore or re-fabricate a dial for a radio being restored.
This topic is especially relevant for glass dials. This is because they are one of the most common types of dials. Secondly, in a good third, if not half, of the cases, over the long life of an antique radio, this most fragile and vulnerable part often ends up, at best, simply peeling from age, or at worst, cracked or shattered.
While cutting a glass blank to the required size isn't too difficult, applying a highly detailed, often colorful, design to it is a very challenging task for a homebrew project.
This task is usually accomplished using silkscreen printing, and you can find a specialist to fulfill this request. The problem is that this method is designed for mass production, while a one-off order would be prohibitively expensive.
I'll attempt to describe in detail two manufacturing methods for glass scales here.
The first is simpler, using color inkjet printing on transparent self-adhesive film. The only drawback is the need for this very film.
The second is more complex, based on thermal transfer of a laser-printed image. However, it doesn't require any specific materials.
Both methods, however, require exceptional care and meticulous attention to detail.
For now, I'll describe the first method. The second stalled due to the poor performance (smearing) of my color laser printer. As soon as I get it up and running, I'll return to this topic.
If you want to work, lie down and sleep, and everything will pass.
(This post was last modified: 07-04-2026, 07:01 PM by Vlad95.)
Threads: 7
City: SPRUCE GROVE
I'm currently working on one of the first vacuum-tube portable radios of the USSR, the "Dorogny." Unfortunately, it had no dial at all, lost in the mists of time.
This is a picture of it from the internet.
[Image: https://radionostalgia.ca/My_collection/...jniy-2.jpg]
Threads: 7
City: SPRUCE GROVE
Fortunately, the scale drawing for this radio was found online many years ago and was thoughtfully stashed away in the computer's memory.
The drawing was straightened, calibrated for printing at the correct size, and mirrored in accordance with the required technology.
[Image: https://radionostalgia.ca/My_collection/...ale-11.jpg]
[Image: https://radionostalgia.ca/My_collection/...ale-12.jpg]
Threads: 7
City: SPRUCE GROVE
Glass blanks were cut out. The scale of a Nov radio receiver, a virtually identical clone of the Dorozhny radio, served as a template.
I highly recommend sanding the ends of the blanks with a diamond stone to avoid injury during the subsequent meticulous work.
[Image: https://radionostalgia.ca/My_collection/...ale-01.jpg]
Threads: 7
City: SPRUCE GROVE
Here is a package of transparent sheets for printing self-adhesive stickers on an inkjet printer.
[Image: https://radionostalgia.ca/My_collection/...ale-02.jpg]
Threads: 7
City: SPRUCE GROVE
The scale is printed. It has a cutout to make the pointer visible. The film, although transparent, is matte, making it difficult to see anything that isn't directly adjacent to it.
[Image: https://radionostalgia.ca/My_collection/...ale-08.jpg]
(This post was last modified: 07-04-2026, 07:12 PM by Vlad95.)
Threads: 7
City: SPRUCE GROVE
The first test of the scale revealed that the printed image was not very durable and smudged easily.
[Image: https://radionostalgia.ca/My_collection/...ale-09.jpg]
Therefore, a protective sticker was applied to the printed side, in which a reticle window was also cut.
[Image: https://radionostalgia.ca/My_collection/...ale-05.jpg]
[Image: https://radionostalgia.ca/My_collection/...ale-06.jpg]
Threads: 7
City: SPRUCE GROVE
The glass blank is thoroughly washed and degreased with alcohol. The protective paper is removed, and the design is glued to the glass. The excess is trimmed off, and the scale is ready.
[Image: https://radionostalgia.ca/My_collection/...ale-07.jpg]
Threads: 7
City: SPRUCE GROVE
The body of the radio receiver with an installed scale.
[Image: https://radionostalgia.ca/My_collection/...jniy-1.jpg]
Threads: 23
City: Greenlawn
State, Province, Country: NY
NICE!!! Great job, Vlad!! Wish there was a pdf of the dial scale for my Telefunken Allegro. Glass is broken but glued back together. However, the break is noticeable.
Threads: 7
City: SPRUCE GROVE
Hello, MrFixr55,
I think in your case, you can create an image file yourself from the existing glass. This can be a problem if the glass is lost, as in my case. However, if the original glass is still intact, you can do it. Remove the glass from your radio, take a photo of the existing glass in the highest possible quality. Then, use a graphics editor to correct cracks and other image errors.
In my case, I also had to correct image defects and adjust the size. In the attached photo of the finished scale, you can see that the glass is slightly wider than the sticker and has some defects. This happened because the image from the internet was 108 mm by 28 mm, whereas the actual size should have been 108 mm by 30 mm. Therefore, the final scale was only corrected on the third attempt.
On my website you will find a number of scale drawings and other graphic materials - Scales
(This post was last modified: 07-04-2026, 10:45 PM by Vlad95.)
Threads: 226
City: Omak
State, Province, Country: WA
Hello Vlad,
Wow, that takes a lot of patience to do, and it looks great! I’ve never attempted anything like that before.
Threads: 46
City: Lapeer, MI
State, Province, Country: USA
With Vlad's permission, I would recommend this post be placed in the "Important Threads" section of the "Other Radios/Phonographs" Category. Vlad this is an amazing post  ! Joe
Threads: 226
City: Omak
hello Joe,
I too agree great idea !
Sincerely richard
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
| The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 195...David — 10:51 AM |
| Dale: Modified topic as suggested. It is not for a specific project. I found it in a box of stuff I recently purchased...GRG — 10:34 AM |
That looks a lot like an aircraft connector of some kind ...
That is a MIL-5015 style connector, used in a wide v...DaleHCook — 10:19 AM |
| I would suggest changing the topic from "P45-6365 Universal Transformer" to "45-6365 Universal IFT."...DaleHCook — 10:08 AM |
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
| hello david,
There are currently 1305 online users. [Complete List] » 4 Member(s) | 1301 Guest(s)
