What Audio Transformer To Buy?
I have a Philco 40-190 and the audio output transformer is DOA. I looked at all my parts sets and no match. AES, Radio Daze etc. have audio output transformers but I honestly don't know which one to buy. Could someone give me a little guidance as to which one will work?
http://www.nostalgiaair.org/PagesByModel...013339.pdf
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
I don't think it's that critical, somewhere between 5 and 10 K primary impedence and 4 or 8 ohm secondary should work out fine. Can't do any harm trying out something you may have in your stash provided that it is not shorted or open. Do find out why the old one burnt out before going further. Transformers are pretty sturdy untill crossed.
Thanks Fox! I look at Radio Daze again. There's just such a huge selection there I wasn't sure which to choose. As for why it went open on the primary side I just have no idea at this time. I'm disassembling the whole radio because of all the bad wiring and I'm finding all kinds of problems that could have caused it. The wiring is so bad and I do see lots of areas where shorting took place. Burnt areas on the chassis etc.
Pepper
Hi,
According to RCA receiving tube manual RC-13, 1937, the load impedance of a 41 tube operating at a plate voltage of about 180 volts, where your 40-190 is at, should ideally be about 9,000 ohms. A push-pull 41 operation would be about twice that or about 18k ohms. A Hammond universal type push-pull center tapped primary audio output transformer gives you taps to select the pimary and secondary impedances you wish to match up to. See the Hammond catalog on the Radio Daze site. A Hammond 125A at 3 watts or a 125B at 5 watts should work for you. The 40-190 is rated at 2 watts audio output power per the schematics. You can measure the speaker voice coil DC resistance with a ohmeter to determine it's approximate impedance with the secondary of the audio output transformer disconnected. Multiply the ohmeter reading by 1.25 to get the impedance. This is then the secondary impedance you wish to match. Use the universal impedance chart supplied to match to the pimary and secondary impedances ideally needed for good match. I personally would go with the 125B for current handling headroom. Icon_smile Good luck, John
I'd just like to clarify the connections on this Hammond 125B audio transformer I just put into this 40-190. Primary side's pretty simple but I want to make sure that I have my secondary side correct. My voice coil reads about 4 ohms so I'm using pins 4 & 5 of the transformers secondary. Pin 4 is connected to chassis ground and pin 5 to my speaker. Is this correct?
http://www.hammondmfg.com/pdf/5c0054.pdf
Pepper
Pepper,
You may try different secondary connections to get the best operation...loudness and quality. With a 4 ohm secondary impedance you go down the 4 ohm vertical table to get a match close to the theoritical primary tube load impedance. In this case around 18kohm.
So it looks like connections to secondary pins 1 & 3 with one being the ground would give you about 15kohms. Pins 5 & 6 with 5 being ground would give you around 22kohms primary load impedance. Icon_biggrin See what works best for you. Icon_clap
John
Thanks John I'll experiment with it. I powered the set up and I have the local AM station coming in faintly but tuning the radio makes no difference. I still get the local station no matter where I'm at on the dial. So I've got some bugs to work out.
Pepper
Pepperoni Wrote:Thanks John I'll experiment with it. I powered the set up and I have the local AM station coming in faintly but tuning the radio makes no difference. I still get the local station no matter where I'm at on the dial. So I've got some bugs to work out.
Pepper
That's a symptom of a dead local oscillator.
-Bill
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2327 online users. [Complete List]
» 2 Member(s) | 2325 Guest(s)
