cap question
I want to restuff a metal cap (non elec) it is a .50uf. The only cap I have close is a fat .47uf which will not fit inside the metal housing. Could I use two 1.0uf caps in series, or 2 .44uf caps in parallel? Im not sure what that does to the voltage value. The 1.0uf caps are only 400v, and the .22uf caps are 630v.
-Keith
Two 1mFd caps in series would be 0.5 mfd, if it would fit....
Seems like I saw 0.5mFd electrolytics somewhere, they should be small enough to work in the can....
Here is a link to a site that sells .47mFd electrolytics, but they are radial lead, not axial.
http://www.sterenshopusa.com/catalog/sea...CAPACITORS
Two .22 caps would be fine. Still 630V.
Sorry I wasn't clear the cap I'm trying to restuff is non-electrolytic. If I could parallel two .22 caps and get .44 and keep the voltage at 630V i'll go that route. Should be close enough to .50uf to work right?
-Keith
Yes, that will work just fine.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2328 online users. [Complete List]
» 2 Member(s) | 2326 Guest(s)
