resistor wattage
Hi Guy,s
Replacing some resistors on my RCA model 816k radio and have a question about a resistor shown on the schematics.
Its labeled c30 on the schematics.
It is specified as a 320 ohm carbon type resistor,but I am not able to read what the wattage is on my parts list.
Any body know if this one is a 1/4 watt or a 1/2 watt resistor?
THanks,
murf
R30 looks like 820 ohm 1/2-watt to me:
http://www.nostalgiaair.org/PagesByModel...015155.pdf
Carl
Northern Panhandle, WV
cwtravis Wrote:R30 looks like 820 ohm 1/2-watt to me:
<!-- m --><a class="postlink" href="http://www.nostalgiaair.org/PagesByModel/155/M0015155.pdf">http://www.nostalgiaair.org/PagesByMode ... 015155.pdf</a><!-- m -->
Thanks for the clarification.
Would have been in trouble using a 320 ohm.
murf
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
