Using a Signal Generator
Hi all,
I just bought a EICO 330 Signal Generator and will use it to isolate defects in specific stages. It has a coax output cable with alligator clips.
Everything I read, including the EICO manual, stresses that I put a .01 mf cap in the negative lead and a 200 pf cap in series in the hot lead. I don't understand. I can solder a cap on the ground and clip onto it, but how do I put the cap in series in the hot lead and use it to probe?
Alan
Hi Alan,
The reason for these two caps is to block any voltage which present in the tested circuit from being applied a cross the output of the generator and to match the impedance of the generator output to the circuit.
If you are working on a set that has a power transformer then you wouldn't necessarily need the cap in the ground leg. If you are using it on a transformerless set you will need it or an isolation transformer.
The cap in the output side could be installed inside the generator where the wire connect internally. You could check the diagram to see if it has a cap in series with the output, don't think two would be necessary. Both of these caps should have a voltage rating of 500v or better, no low voltage stuff here.
Now I think I've got it!
on the hot lead clip one end of the cap to the alligator clip and use the other lead on the cap as your "probe"
John
Las Vegas, NV USA
Thanks guys, I guess I knew what to do, but I feel like I'm guessing until I get the reassurance and support from you. Thanks so, so much for your replies!
Alan
I usually use a coil of about 25 turns of any kind of wire on aTP cardboard and wire it with a .05 cap in series with the signal generator. Good enough coupling for most purposes, but if you want to work backwards from the second IF, etc.. follow alignment instructions. Beware you can be nipped slightly or fatally when working with an old signal generator and old hot chassis radio if you are not careful. Please use an isolation transformer. You can also get an inexpensive new or surplus frequency counter to see where you are from the Eico. Mine is off by a lot, but at least I know how much and in which direction.
