Radio Daze Philco dial reproductions
Good evening, I'm just about finished restoring my Philco 37-650B and I need to order a dial for it. I thought about ordering a dial from Radio Daze. Are their dial reproductions any good and is the artwork accurate on the dial?
Hi Ken
If you like pale yellow, almost white, dial scales - then, yes, I guess you could say they are good. If they are still using the Rock-Sea artwork (and I believe they are), then the artwork itself is accurate - just the color of the dial scales themselves that are too light.
Send me a PM with your mailing address, I'll send you a 37-650 scale, free. I think you'll like it better than a RD repro.
Hi Ron, I sent a PM to you. I have ordered some dials from Mark Oppat in the past but the dial color can vary considerably that was why I wondered about the Radio Daze. Have a great evening! Thanks, Ken
PM answered.
Some of Mark's dial scales are a bit dark. But his have the advantage of being translucent. Laminated dial scales such as the ones from RD do not let as much light through, but are better than nothing.
I've experimented with making my own scales. Like the RD scales, mine are laminated. But I try to make the color of mine as close to original as possible, rather than pale yellow. These look a lot better inside the dial window, whether the set is on or off.
Anyone can do this; all they need is a good scanner, good photo editing software, and a little patience. Icon_smile
The Rock-Sea dials can be made into the correct color with a spray of transparent orange (from a hobby shop) followed by a matte spray. The color and transparency match the original Philcos perfectly.
Pete AI2V
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
