Philco 87 B+ Current?
Anybody know how much total B+ current this radio should pull (as measured right off the #80 rectifier filament pin) ?
I have measured around 120 mA on one of these sets which seems to be working fine, but I don't know if this is normal or if it is too high. I haven't replaced the filter condensers and I really don't want to get into that if I don't have to. I am measuring the current based on the voltage drop across a 0.100 Ohm resistor using a Fluke 189 meter on the DC millivolts scale.
As it is, the power transformer runs a little hotter than I like, and I'm thinking this may be due to excessive load on the B supply. When I plug in a very weak (good filament, zero emission) #80 tube, the transformer runs barely warm, so I'm pretty sure that a good part of the heat is coming from the HV winding load. I just don't know how much is "normal".
DD
You say the set you measured "seems" fine, but have you replaced all the filter block caps and other wax-paper bypass caps?
  • Excessive leaky B+ bypass and filter caps can cause excessive current draw and warmup your transformer and ultimately kill it and the 80.
  • Check for winding to winding or winding to case shorts in the audio output transformer. Bad shorted output tube(s).
  • Check for carbon burns bewtween pins on the 80 socket.
  • Check for shorted filter chokes. #3422 = 200 ohms, #3472 = 1,350 ohms.
  • Check for shorted field coil - should be approx. 3,200 ohms.
  • The filter block caps can be replaced with like-value film caps. They don't need to be electrolytic.
  • It's a good idea to replace any resistors that are more than +/-20% off value as well. Imprpper audio tube biasing can make them draw excessive current. Check resistor #35, a three section wire-wound. The cathode bias section should be approx. 640 ohms.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
