48-482 volume control.
My daily use player is a 48-482 that I recapped a few years ago. It now needs a new volume control. How do I add the 1m centertap to the 2m pot? Also should this be an audio taper or linear? This my first post. Thanks for allowing me to participate.
Roger
Thank you for joining, Roger. Icon_smile
Are you sure the old volume control is bad? DeoxIT D5 sometimes works wonders on old volume controls. Pricey, but worth the cost. You will probably have to order it online as it is not easily found in stores.
Thanks for your reply, Ron. I have Deoxit D5 in stock, but in this case, the shaft of the pot is actually loose and intermittant.
You may need to contact Mark Oppat, he will have a control you can use, with the proper tap for bass compensation.
http://www.oldradioparts.net/
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
There are currently 578 online users. [Complete List]
» 2 Member(s) | 576 Guest(s)
