Philco Round top radio (38-1139???)
Hello everyone
I have a Philco round top radio. The only number I can find is 38-1139 this number is under the chassis. Is this the model number I cannot find anything about it on the internet. Nostalgia does not have it listed.
It has 0ne 80, one 42, and two 77 tubes. I can get the 470 KC tuned ok but I cannot get a broadcast signal thru. It has a "gimmick" type coupling between the osc and the det and I am not sure if that is working, it was unwound when I started to work on it. The radio seems to be a copy of a Philco 37-84 but the tube lineup is very different. Does anyone have any info on this??
Thanks Joe
My research fits the Philco model 81 ca. 1932-33.
http://www.nostalgiaair.org/Resources/852/M0013852.htm
Richard
Yep. Sounds like the Model 81. You may also want to look at these two pertinent Service Tips from my site:
http://www.philcorepairbench.com/tips/svctip44.htm
http://www.philcorepairbench.com/tips/svctip07.htm
You may have an open coil or two -- use your meter to check for continuity of all coils. Early Philcos suffer from green corrosion disease on older coils.
Hey Thanks Guys
With your help I found it. The radio is a Model 84 it is very close to the model 81 but I checked 80,81, and 84. It is a model 84 no doubt
but your help lead me right to it.
Chuck your tips will help me put this jewell back in service.
Many Thanks
Joe
Philco 60 Squealing
Philco 60 Squealing
Philco 42-1008 conversion kit
12' Philco
Shadow Meter Bulb
Shadow Meter Bulb
Model 28L
37-60 revision 6
There are currently 6359 online users. [Complete List]
» 2 Member(s) | 6357 Guest(s)
