philco 37-650
Hey all this is my first post and first radio project.I found the problem to do with the drawing and the schematic for the philco 37-650...and then found it on your site,My question is i believe mine is all original so as long as i replace componets where they were ..should it work..assuming it worked from the factory?thanks and cheers Mike
Mike123, hi. provided the set is as it came from the factory your method of replacing individual components one at a time will work. I assume you are talking about resistors and caopacitors. Coils, transformers and other items are not that easy to replace and some ay be damaged. The first task should be to change the filter caps (electrolitic) in the power supply then bring it up with a dim bulb rig. It may be operating. I would not try powering up until the filter caps are changed. PL
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
There are currently 819 online users. [Complete List]
» 1 Member(s) | 818 Guest(s)
