Where to find a pilot lamp for my 37/34
Am going to restore a 37/34 that has been around here for years. I have obtained a 6 volt wincharger system and now would be the time to have the old 6 volt radio restored.
A quick inventory of needs include the pilot lamp which is Philco part # 34-2150. Where can I find this bulb? The list on Chucks site does not have a generic bulb number listed for that Philco part. It is part of the series filiment string with an odd current rating.
If one cannot be found I could double a couple bulbs with half the current rating but would like to find an original if they are available.
Don
Yes you can parallel them to increase the current rating. What color is the bead just below the filament in the lamp?
ps I have the same set as a farm radio 37-33. You'll be surprise at it's performance!
From the 1941 Philco parts catalog:
34-2150 - 2.1V, 0.12A (120 mA). It has a miniature bayonet base and a tall cylindrical bulb.
You could substitute a #49 which uses half the current (0.06A or 60 mA). Less current is good for battery drain, but the bulb will not be as bright.
Terry, the bead color is missing along with the original bulb.
Ron, If I substituted a single 60 mil bulb wouldn't the voltage double acorss it and burn it out. It is in series with two other tubes and current would have to match. If less, the tubes would be starved for current and the bulb would have to handle the voltage lost.
I could hide the other bulb under the chassis I guess.
Don
OK, strike that.
DUH! Winning! Losing!
ahem...anyway, yes, I should have looked at the schematic first. If this were a parallel-filament circuit, it would work with no problems.
Very interesting filament wiring scheme. Three of the tubes are connected across the 6VDC line, with two others in series with the pilot lamp and resistors (7) and ( 8 ) also being across the 6VDC line.
Yeah convert it to take 2 of the #49 bulbs in parallel to replace the original. Make sence as the audio tube fillament is 2v/240ma and the mixer is 2v/60ma + the two resistors to limit the current.
Hickok AC51 tube tester
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
There are currently 5584 online users. [Complete List]
» 1 Member(s) | 5583 Guest(s)
